Large batch move of point FC
1595
03-13-2019 05:58 AM
JotHall1
I'm creating a new point FC from an existing point FC. I have 600,000 address points in my database and a department a my work wants their own service point FC using the address point FC as a template. The catch is they don't want them to overlay the address point FC on the map. My question, how can I do a mass shift to slightly move the position of these new service points off of the existing address point I copied them from?
JimCousins
You could load your data, and perform a spatial adjustment.
Your could edit your points, and use "Move" to offset them.
If you have some experience with arcpy, here is a snippet of code that may help you:
Regards,
Jim
Shifting features
Shifting (or moving) features is a snap using the arcpy.da module’s UpdateCursor. By modifying the SHAPE@XY token, it modifies the centroid of the feature and shifts the rest of the feature to match. This approach will hold for point, polyline or polygon features.
To modify only a single or subset of features in a feature layer, apply a selection to that layer and pass the layer in as the input to shift_features.
Word of caution, this is using UpdateCursor, so features will be permanently modified. So, back up your data if you may potentially want to reverse the updates.
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
import arcpy
def shift_features(in_features, x_shift=None, y_shift=None):
    Shifts features by an x and/or y value. The shift values are in
    the units of the in_features coordinate system.
    Parameters:
    in_features: string
        An existing feature class or feature layer.  If using a
        feature layer with a selection, only the selected features
        will be modified.
    x_shift: float
        The distance the x coordinates will be shifted.
    y_shift: float
        The distance the y coordinates will be shifted.
    with arcpy.da.UpdateCursor(in_features, ['SHAPE@XY']) as cursor:
        for row in cursor:
            cursor.updateRow([[row[0][0] + (x_shift or 0),
                               row[0][1] + (y_shift or 0)]])
    return
