ArcGIS server connectivity issue after re-installing web adaptor
1117
02-14-2019 09:15 AM
SagarSharma
I am using ArcGIS server 10.6. I had to unregister my web adaptor for some reason. I have re-installed the web adaptor and configured to use server application. I am able to connect to the server from other machines on network using computer name but getting issue while using IP address to connect .
Any help will be delightful. Also I have mapped server local IP with and public IP to use this globally.
I am not sure changing web adaptor will have any issue with mapping.
AdrianWelsh
MVP Honored Contributor
Hi Sagar,
It looks like you have your thread marked as "Assumed Answered". Is your issue resolved? If so, please provide a description on what you did. If not, it would be helpful to uncheck it as "answered" and maybe move this thread to the ArcGIS Enterprise‌ space for more visibility.
SagarSharma
Hi Adrian,
Server machine was not allowed to be accessed from outside network due to firewall configuration. However, I didn't made any changes in firewall but still firewall rules got changed may be due to window update.
Configuring firewall again allowed connection to server.
Sam
