Can someone please explain how to use the Scale function in the Image Georeference panel in ArcGIS Pro?
When I select scale, the image goes transparent a bit and a yellow dot appears at the center of the image:
If you hover the mouse over this yellow dot you can see what appear to be 'grips' at the corners and mid-edge point on the image, but as soon as you move off the yellow dot these disappear:
I've tried clicking the yellow dot and dragging, but this just causes the image to again disappear off screen?
What am I missing?!?
