Collector App. Why does adding a point default to GPS location?
1170
01-31-2019 02:55 PM
deleted-user-yC5VkbyXzrQR
When I'm using the new collector APP online (not offline) on my iPhone,  whenever I try to add a point it defaults to the GPS location. Is there a way just have to have collector stay at the location you choose to start to edit ??
Regards,
Adam
Kylie
by Esri Regular Contributor
Hi Adam -- You can choose to collect at your specified location instead of using your GPS location. Are you using Collector or Collector Classic?
If using Collector, see Capture > At a location on the map (the same topic includes how to collect at specific coordinates or at the location of an existing asset, depending on where the non-GPS location you'd like to use is coming from).
If using Collector Classic, see Add a feature > Collect a feature at a particular location.
Esri Education Team
Kylie
Esri Education Team
I see. I got it to work! Thanks.
The new Collector App.
