Disable Export Data in ArcMap
2846
6
01-25-2019 03:13 AM
Wan_Mohamad_NazmeenWan_Othman
Hi All,
I have an image service stored in my server (federated). When i load this image service in ArcMap, is it possible to disable the Export Data capability? I just want the user to visualize and do analysis from my image service without having abilities to export data.
Your further assistance is highly appreciated. Thanks.
Kindly regards,
Wan
GuenterDoerffel
Hi Wan,
sure you can disable download of data. You can do this starting with the MosaicDataset you created. In the "Defaults" section of each Mosaic, there is
if you set this to 0, you disabled Download on the Mosaic Level.
On the Service Level, the same capability can be set to "limit" what you might have set on the MosaicLevel. The "Service Properties" in the "Imaging" section
have a Operation list to allow/disable. Download is one of them:
So even if you allow download on the MosaicDataset level (say so local users using the MosaicDataset have access to the files behind it), you can disable the capability on the service level.
Hope that helps!
Guenter
Great!. Thanks for your detail explanations.
Regards,
Wan
GuenterDoerffel
Pleasure,
but later I ralized it might not be the answer you were looking for: I answered to "download data" - whereas if you ask for the simple "screen export" function in ArcGIS Pro/ArcMap ... there is no way of disabling this: It basically takes the image already delivered to the client and saves it as a "picture" ... and this cant be disabled.
So I hope the first question was what you really needed
Guenter
Hi Guenter,
Thanks for your clarification. Actually, my intention is, i don't want user have the ability to export my raw imagery data that are stored as image service, when they access in ArcGIS Desktop. User just limited to visualize and perform analysis only from the image service in ArcGIS Desktop but they can't export the imagery. Is it possible to achieve this?
Thanks.
Kindly regards,
Wan
GuenterDoerffel
Hi again,
well thats perfect - because that is excactly what I have described above. So yes - this is possible
sajjadsaeed
Hi, i have the same query regarding export capability for ArcGIS desktop level. Currently we are using SDE with oracle. we want to disable the export/copy/paste functions at user level means Editing users must not be able to copy paste feature classes/Feature datasets from Arcmap and ArcCatalog. Any guidelines or workout to implement this security check will be appreciated as i could not find any help on google.
