Remove graphics from legend but keep them in the printed map in ArcGIS JavaScript 4.x
2920
7
11-20-2018 10:32 AM
DanielWebb2
I’m currently using ArcGIS JavaScript API 4.5 but hope to move to 4.9 soon.  Either way, the issue is the same even on my test 4.9 app.
I want graphics, such as draw, to show in the printed map but not in the legend.  The JS 3.x API would do this but 4.x makes a legend item which says “polygonLayer” and the graphic called “Override 1”. This makes the printed map look silly. (see attached image)
I followed advice found here and intercepted the Print request and removed my graphics layers from the operationalLayers in the Web_Map_as_JSON.  However, this also removes the graphics from the map.
 So in 4.x, is there a way to keep graphics in the map but remove them from the legend?
Thanks!
RobertScheitlin__GISP
Daniel,
  In 4.x you have the legendEnabled property for the layer:
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#legendEn...
DanielWebb2
Does GraphicsLayer have the ' legendEnabled' property?  I tried setting it to false anyway but it doesn't work.  The graphics still appear in the legend.
Daniel,
   A GraphicsLayer does not have that property. So you should switch from using a GraphicsLayer and use a FeatureLayer instead. A FeatureLayer has a source property that is an collection of graphics.
Create a FeatureLayer with client side graphics | ArcGIS API for JavaScript 4.9
DanielWebb2
I did the FeatureLayer thing instead, set legendEnabled to false, but they still show in the legend. Only now they have a long id as the title.
Daniel,
   When you say legend you mean the print output legend? If so I am sorry we have been miscommunicating. The legendEnabled is for the legend widget in the map.
DanielWebb2
Yes, this is for the printed legend in the printed map.  Is there a way to remove graphics from printed legend but to keep them in printed map?
I was thinking that they fixed the override label in the print legend in ArcGIS Server 10.6.1...
