Change Data Store Install Directory
3141
11-08-2018 05:57 AM
MichaelSchoelen1
Because of a server policy, the installation directory for ArcGIS Data Store was set to
D:\Program Files\ArcGIS\Datastore
rather than
C:\Program Files\ArcGIS\Datastore
So far, this hasn't caused any problems (we only use a relational tile store), but we are noticing an issue when upgrading from 10.5.1 to 10.6.1 during the final stage of Complete Upgrade. It might be related to this technical article regarding spaces in the filename.
Is there a technical article on how to change the installation directory of DataStore? Its high-availability, so my one thought is just to un-pair them, reinstall one to a directory with no spaces, rejoin, then do the same with the other data store.
by Anonymous User
Not applicable
Hi Michael,
I was able to find this article on changing the default folder location can be changed using ArcGIS Data Store command utilities from the Windows Command Prompt
How To: Change the ArcGIS Data Store default folder location to a different storage drive
Similar Questions Related:
Move Portal Datastore from C: drive to 😧 drive
ArcGIS Builder Configuration Error - Data Store
Let me know if you have questions.
Best,
Luba
