Problems with the Create Mobile Map Package GP tool
3596
8
10-26-2018 12:23 PM
MichaelHamsa
I running the Create Mobile Map Package GP tool, and I'm getting this error. Is there a log of any sort that I can refer to see what table and or field is causing this error? I've turned on "Write geoprocessing operations to XML log file", but I'm not getting any XML log files for this GP.
 ERROR 999999: Something unexpected caused the tool to fail. Please refer to the error help for potential solutions, or contact Esri Technical Support http://esriurl.com/support.
 A date conversion error has occurred.
 Failed to execute (CreateMobileMapPackage).
Mike...
DanPatterson_Retired
Create Mobile Map Package—Data Management toolbox | ArcGIS Desktop
no mention of 'dates'... what, if anything, do you have with dates in it?
MichaelHamsa
Dan,
Thanks for the quick response. The map I'm dealing with has 113 layers, each with quite few properties. I know we've got several date type fields in there, but I was hoping there was some type of log file that would give me a bit more of an idea about which layer and field to look at. Right now it's just an "unexpected" error about a failed date conversion, without any other detail, so my only option is a lot of trial and error to identify exactly where the problem is.
Are there any log files I can refer to and get some more details about this error?
Thanks again,
Mike...
Michael... from here
Geoprocessing options—ArcGIS Pro | ArcGIS Desktop
under Logging it is stored in your profile if you log to xml log file
but I don't log to xml... the setting is on your Project, Options Geoprocessing page
It may not be logged and I am not sure what is and isn't.
You might want to try toggling on both options if you haven't done so
MichaelHamsa
Dan,
Thanks - I've turned those options on, but the XML log file I'm getting (attached) isn't providing any more detail. Is there anything log I should be getting?
mike...
I see nothing obvious, it would be best to forward to tech support
MichaelHamsa
Thanks Dan – I’ll do a little more research to try to get a better handle on what’s causing the problem, then forward the details over to tech support.
Mike Hamsa
Chief Technology Officer - GeoSpatial Innovations, Inc.
P: 512-982-6735
MarkBockenhauer
Michael,
Try halving the layers.... copy paste half into a new map in the project and create package, to  narrow down to the specific layer... and repeat until found.
what data sources are in your map... file geodatabase, shapefile, services ?
I have not encountered this error and am not aware of any date field conversion issues.
if you can share data to reproduce the issue with me, I would appreciate it.
thanks
Mark
MichaelHamsa
Mark,
I’ll do some more work to try to figure out what’s causing the problem using these suggestions. I was just checking to see if there was some additional detail in a log somewhere that may help narrow things down a little.
Thank you very much.
Mike Hamsa
P: 512-982-6735
