Export Web Map to image
3356
10-18-2018 07:13 AM
deleted-user-MOQmQl8Sb2hg
I am trying to export a web map constructed in python (1.5.0) as an image, however, when sending the web map to the export_map call, the JSON appears to be missing the MapOptions section of the JSON that is needed. Any thoughts on what I am missing?
search_result = gis.content.search(query="title:" + carrier + "_In-Force", item_type="Feature Layer")
print(search_result[0])
search_result_HU = gis.content.search(query="title:Michael_10_12", item_type="Feature Layer")
print(search_result_HU[0])
wm = WebMap()
wm.add_layer(search_result_HU[0], options={'title': 'Hurricane', 'opacity': 0.5})
wm.add_layer(search_result[0], options={'title': 'Locations'})
print(wm.definition)
output = mapping.export_map(web_map_as_json=wm, format='PNG32')
print(type(output))
When calling the export_map, I am getting the following error:
Error executing tool. Export Web Map Task : 'mapOptions'
Well I solved my own issue.
I manually added the MapOptions and exportOptions to the webMap JSON.
webmapJSON = web_map_item.get_data()
webmapJSON.update(json.loads('''{"mapOptions" : { "extent" : {  "xmin":-88.55,  "ymin":17.55,  "xmax":-72.75,  "ymax":38.05,  "spatialReference" : {   "wkid" : 4326  } }}}'''))
webmapJSON.update(json.loads('''{"exportOptions": { "dpi" : 300, "outputSize" :  [1000,1000]}}'''))
From here, you can call the export_map function and the image will be rendered.
Also, beware that your layers must be marked public for this to work.
simoxu
by MVP Alum
Thanks for sharing.
