python script not working
3556
10-17-2018 08:08 AM
devarsimajumder2
I am trying to find out why the python script that I wrote isnt working. I am trying to count  the number of stairs in a stairwell. I have two shapefiles and i wrote the script to run auto and process how many stairs there are.  if someone can help me with this I would appreciate it thanks.
JoshuaBixby
MVP Esteemed Contributor
Sharing with Python‌ since this looks to be ArcPy and not ArcGIS API for Python.
Please paste the code (not a screenshot) and use /blogs/dan_patterson/2016/08/14/script-formatting?sr=search&searchId=bdf45239-640f-4c59-b3e5-bbc4c8d...‌.  Also, provide the error and traceback if you are getting an error.  If you are seeing unexpected results, describe what you are seeing and what you expect.
devarsimajumder2
here is the code below. again im not too  familar with  python  so  i am asking for some help
def createInternalParallelLines():
# import libraries
import arcpy
# set input/output parameters
polyFC = arcpy.GetParameterAsText(0) # input polygons
outParallel = arcpy.GetParameterAsText(1) # output parallel lines
lineSpacing = arcpy.GetParameterAsText(2) # line spacing
buffDist = arcpy.GetParameterAsText(3) # inner buffer distance
# parse numbers from parameters
lineSpaceNum = float(lineSpacing.split(' ')[0])
buffNum = float(buffDist.split(' ')[0])
# establish spatial reference
desc = arcpy.Describe(polyFC)
SR = desc.spatialReference
# set overwrite environment
arcpy.env.outputCoordinateSystem = SR
parallels = []
# create hull rectangle to establish a rotated area of interest
coordSplit = row[0].hullRectangle.split(' ')
# collect corner coordinates
coordList = arcpy.Array([arcpy.Point(coordSplit[0],coordSplit[1]),arcpy.Point(coordSplit[2],coordSplit[3]),arcpy.Point(coordSplit[4],coordSplit[5]),arcpy.Point(coordSplit[6],coordSplit[7]),arcpy.Point(coordSplit[0],coordSplit[1])])
# create lines from hull rectangle
currentLines = []
for pointNum in range(0,4):
arcpy.Array([coordList.getObject(pointNum),coordList.getObject(pointNum+1)])
hullRecLine = arcpy.Polyline(arcpy.A
# loop through each input shape
for row in arcpy.da.SearchCursor(polyFC, ["SHAPE@"], spatial_reference=SR):
# create inner buffer
polyBuff = row[0].buffer(buffNum * -1)
rray([coordList.getObject(pointNum),coordList.getObject(pointNum+1)]))
currentLines.append(hullRecLine)
# compare first and second line to determine if first line is short or long
firstLong = 0
if currentLines[0].length < currentLines[1].length:
firstLong = 1
# calculate number of points needed along short axis
numPoints = int(math.floor(currentLines[firstLong].length/lineSpaceNum))
# create and join points to create parallel lines
for point in range(1,numPoints+1):
shortPoint1 = currentLines[firstLong].positionAlongLine(lineSpaceNum*point)
shortPoint2 = currentLines[firstLong + 2].positionAlongLine(currentLines[firstLong + 2].length - (lineSpaceNum*point))
parallel = arcpy.Polyline(arcpy.Array([shortPoint1.centroid,shortPoint2.centroid]), SR)
# intersect parallel lines with buffer
parallelBuff = parallel.intersect(polyBuff,2)
parallels.append(parallelBuff)
# write geometries to disk
arcpy.CopyFeatures_management(parallels, outParallel)
# add to map
mxd = arcpy.mapping.MapDocument("CURRENT")
dataFrame = arcpy.mapping.ListDataFrames(mxd, "*")[0]
addLayer = arcpy.mapping.Layer(outParallel)
arcpy.mapping.AddLayer(dataFrame, addLayer)
del row
devarsimajumder2
Here is the code… thanks for your help
  1. import libraries
import arcpy
  1. set input/output parameters
  1. parse numbers from parameters
  1. establish spatial reference
  1. set overwrite environment
parallels = []
  1. create hull rectangle to establish a rotated area of interest
  1. collect corner coordinates
  1. create lines from hull rectangle
currentLines = []
arcpy.Array()
  1. loop through each input shape
  1. create inner buffer
rray())
  1. compare first and second line to determine if first line is short or long
firstLong = 0
firstLong = 1
  1. calculate number of points needed along short axis
  1. create and join points to create parallel lines
parallel = arcpy.Polyline(arcpy.Array(), SR)
  1. intersect parallel lines with buffer
  1. write geometries to disk
  1. add to map
del row
DanPatterson_Retired
Follow your other post
https://community.esri.com/thread/222977-arcpy-scripting-error-question
and use the code formatting link in there.
There are other unaddressed questions as well.
