Area feature from point feature
1408
10-12-2018 02:42 AM
ayllaBAK
Hi all,
Please, can anybody help me. I need to create buildings (area feature) from  point features. I only have 1 point for 1 building. So I need to create some buffer around that point  but with rotations.
Thank you in advance....
Your desperate
DanPatterson_Retired
You might want to show what you have since if you buffer a point you will end up with a circle and rotating a circle isn't very useful.
You can look for 'square buffer' samples on geonet if they would be of use
For example
https://community.esri.com/thread/119885?commentID=449371#comment-449371
ayllaBAK
Thank you for a very quick and useful answer. The only thing that is left unsolved is how to add the appropriate rotation to each of these squares. Is that possible? I have a field with rotation values from 0 to 360.
There are code bits around, but you would have to piece the process together yourself.  For example
https://community.esri.com/message/793139-re-randomly-moving-and-rotating-polygons?commentID=793139#...
