Nested repeat issue
3862
12
10-02-2018 11:08 AM
OussamaMerhi
I am trying to use nested repeat as follows:
the first repeats contains the names of different areas and the nested one contains additional information about the area.
First repeat
           Nested repeat
                 Five records entered in this repeat
                  Here is the problem which is that it should reset the number of records and starts from record 1 but unfortunately it continues as record 6.
is there any solution???
JamesTedrick
Esri Esteemed Contributor
Hi Oussama,
Can you confirm the version of Survey123 you are using?  Also, can you share the XLS form?
OussamaMerhi
I am using Survey 123 for ArcGIS version 3.0149. find attached the excel sheet.
JamesTedrick
Thanks Oussama,
I'm not quite seeing the error that you described, but I am seeing that the after the first repeat, the form creates  an equal number of nested repeat entries as was first entered (though the count restarts at 1).  Additionally, I can also see that calculations are not being triggered in the first repeat.  These are both issues that we are investigating to fix in Survey123.
OussamaMerhi
yes after the first repeat the form creates an equal number of nested entries as was first entered but the count doesn't start from 1 for the second nested repeat. Is there any exact date to fix it?
JamesTedrick
Hi Oussama,
We do not have an exact date, though this is a high priority for us to fix.
JohnathanHasthorpe
A fix for the repeat issue is now available on EAC: Welcome to our Feedback Community
Please download the release candidate and test your survey.
John
OussamaMerhi
How can I download this update?
JohnathanHasthorpe
Please sign up to the Early adopter community here: Welcome to our Feedback Community
OussamaMerhi
Hi James,
I have a form in survey 123 which contains 1000 record. I would like to add a repeating table to that form. Publishing the form will delete all the previous records. Is there anyway to add repeating tabling to the form without loosing any previous data .
Best,
Oussama
