Nested repeat issue
4358
12
10-02-2018 11:08 AM
OussamaMerhi
I am trying to use nested repeat as follows:
the first repeats contains the names of different areas and the nested one contains additional information about the area.
First repeat
           Nested repeat
                 Five records entered in this repeat
                  Here is the problem which is that it should reset the number of records and starts from record 1 but unfortunately it continues as record 6.
is there any solution???
JamesTedrick
Esri Esteemed Contributor
Hi Oussama,
Adding a repeating section is a significant enough change that republishing the feature service is required.  I would recommend downloading the existing surveys as a file geodatabase; you can then append the data into the new feature service once republished.
by Anonymous User
Not applicable
Hi Oussama,
Just an update to let you know that we have been working on the issues described in this post and a lot of progress has been made with repeats/nested repeats and defaults/calculations/relevants/groups and missing values when opening the survey, so we believe the issue has been resolved for our upcoming 3.2 release which is due end of January.
If you have time, can you please check out the latest 3.2 RC builds (Connect 3.2.192 and App 3.2.262) available on EAC here: Welcome to our Feedback Community and provide any feedback. The sooner we can get feedback the sooner we can address any outstanding issues before the release.
Regards,
Phil.
OussamaMerhi
Hi Phil,
Thats a good news. I will look at the new version, will test it and report on any issue.
Best,
Oussama
Sent from my iPhone
