Drone2Map does not utilize GPU
6751
9
09-27-2018 01:39 AM
by Anonymous User
Not applicable
I am using the latest build of Drone2Map (v1.3.1) on Windows 10 (1803) x64 with the following hardware:
- Dell Precision 5820
Intel Xeon W-2104 3.2GHz, 4C, 8.25M Cache
- 32 GB RAM
- 1024 GB SSD
- NVIDIA® Quadro® P4000, 8GB, 4 DP
I have checked the "Use CUDA" option and and set the "CPU Threads" to the max. I am trying to render a demo project with around 210 images using the 2D mapping template.
Although the log file shows, that the graphic card is found and that CUDA is enabled, using the GPU monitor shows, that the GPU is never utilized. I have installed the latest NVIDEA Quadro drivers.
Are there additional steps needed to get the GPU involved in the processing?
Kind regards,
Christian
Tags (4)
DanPatterson_Retired
This is the recommendations for the Spatial Analyst extension. I would assume it would be the same for the rest of the suite.  Is it where you got your information?
GPU processing with Spatial Analyst—Help | ArcGIS Desktop
by Anonymous User
Not applicable
Hi Dan,
the only information I found on the Drone2Map CUDA option where from here: Processing options—Drone2Map for ArcGIS Help | ArcGIS
And I found an older thread, but it did not help me to get my GPU involved in the processing: https://community.esri.com/thread/192142-drone2map-killing-my-computer
Regards,
Christian
RockRunEnterprises
Using the Nvidia control panel, select 3D Settings > Manage 3D Settings > Global Settings > Global Presets > "3D App-Game Development > Apply
WalterSmit
Thank you - that fixed it!
RockRunEnterprises
Glad to help!
AsafEvenPaz
Facing the same issue but not seeing any of these options when opening the NVIDIA Control Panel.
Hardware Specs:
NVIDIA:
AsafEvenPaz
Here is the NVIDIA Control Panel:
RockRunEnterprises
Not sure what you are seeing on your side... I access the control panel from simply right-clicking on the desktop and this is what I see. Granted this is installed locally on my workstation, not running through a network or server which could be your issue.
MikeHarrickey
Hi Patrick,
Is there any reason why Global Presets tab doesn't show up in Nvidia control panel?
