How to convert KML to Layer in Arcmap 10.3.1?
1496
09-06-2018 12:56 AM
DhruvilPatel
Steps taken till now:
1) I have drawn a path in my Google Earth and i am trying to import that path into arcmap 10.3
2) I saved the path as RANDOM.kml file in my geodatabase
3) Opened Arcmap and went to the conversion tool: KML to Layer
4) In the Input KML, i selected the RANDOM.kml file from the geodatabase
However, an error 000814 pops up in the input KML section saying INVALID FILE TYPE.
This is a KML file file as shown in my File Geodatabase.
Below you can see the screenshot. NOTE that in the input kml file section the file type is *.kml
THIS IS THE SCREENSHOT OF THE ERROR POPING UP
I am seeking help from the ESRI community on this problem. Your inputs would be invaluable!
DanPatterson_Retired
save the kml to a folder ie c:/temp  and try again
deleted-user-qpvAI3Fo0MKR
Don't save the .kml in a .gdb...as Dan Patterson‌ mentions above, you should store it in a file folder such as c:/temp instead.
