Issue using my survey in browser, works fine in survey123 phone and computer
9339
19
09-04-2018 04:12 PM
by Anonymous User
Not applicable
Hi all,
I am having a weird issue with my survey. It fails to submit when I use the browser and works just fine when I use my phone and PC. Any idea?
Here is the message I get from the logs on Portal:
The submitted field 'undefined' is not available in the layer '0' of the service 'Carr_Fire_Assessment'.
JamesTedrick
Esri Esteemed Contributor
Hi Anneka,
The Survey123 website has been updated to fix this issue - can you please attempt to use the current version?
JamesTedrick
Hi Alex,
Can you share the survey XLS file?
by Anonymous User
Not applicable
James,
I did not find the attach button when i hit reply yo your response so i edited the post and attached the excel spreadsheet to the original post.
FYI the survey was created from a feature service, so I also my Database design.
Thank you,
Alex
JamesTedrick
Hi Alex,
In looking through the form and GDB, there are a few things that might help troubleshoot:
- Is the Feature Service based on the Enterprise GDB or the Hosted Data Store?  There are a couple of field names that might be reserved words.  DBMS, for example.
- You have a few fields that have the same name in different tables.  Technically, there shouldn't be any duplication of field names
Another thing I noticed that might help later on - you've applied a domain to the Hazardous Waste types - that won't work well with a select_multiple question (domains only work with select_one).
by Anonymous User
Not applicable
Thanks James,
1) The feature service is based on a hosted data store on our Portal.
2) Ok, Is that the fields highlighted in red? I will change those and test again.
3) I have added a domain to Hazardous Waste Type because I would like to use this layer either in collector and survey. It would be a single select in collector but a multiple select in survey123. So, Should I create a separate field for collector and one for survey123 without domain (simple text field) so I can do a multiselect?
Alex
JamesTedrick
On the domain - yes, if you want to store and support multiple choice values, that will need to be a separate, non-domain field (or you could make a related table to capture multiple values).  Multiple choice responses are stored as a comma-separated text string; these do not meet the requirements of the domain.  You would also have a type mismatch as multiple choice are text, not integer.
by Anonymous User
Not applicable
That might be a great idea to have a related table to store multiple values so it works equally as well in collector. However the user probably will lose a little of the simplicity of survey123 that lets them choose multiple values all at once. I will test and get back to that discussion once I get it tested. Hopefully once I change some field names and modify the that field that has a domain it lets submit.
by Anonymous User
Not applicable
Same issue. No more fields with same name. Made sure there is no reserved words. No more multiselect for that hazardous waste field. I am not too sure what's wrong with what I have.
JamesTedrick
Hi Alex,
I am seeing the same behavior with a form created from the same feature service.  We're looking into what the issue might be.
by Anonymous User
Not applicable
Thank you James!
