Create a copy of hosted feature layer
2680
08-23-2018 07:56 PM
by Anonymous User
Not applicable
I have a editable layer only viewable to my organization and I want to make a copy without edit capabilities for use on our public facing web map. Would like to setup a script that runs once maybe twice a day to update the public facing layer. Anybody know of a solution?
simoxu
by MVP Alum
I assume you are using AGOL, or you are using Portal with a public interface for the public to access; and your layer is a hosted feature layer.
My suggestion is: Don't copy the hosted feature layer, create a read-only view instead. here is a pretty good article written by Paul Barker:
Getting started with hosted feature layer views
For the instruction on the latest version:
Create hosted feature layer views—Portal for ArcGIS | ArcGIS Enterprise
simoxu
by MVP Alum
by Anonymous User
Not applicable
Thanks! I was unaware this tool was available.
RandyBurton
The only issue I have with views is that you cannot hide some fields (those that cannot be set to null) from sophisticated users.  You can only hide the field from the map's pop-up display.  It is possible for someone to navigate to the view layer for a look. I have been looking for a way to completely hide these fields: Hosted feature layer views and domains.
by Anonymous User
Not applicable
I'll keep that in mind. Thanks for the tip.
