ERROR 000582 - Create a checkout to a file GDB
2762
08-21-2018 11:23 AM
JordanMiller4
we are encountering "error 000582: Error occurred during execution" while executing a python script creating a checkout replica. We were able to create the checkout replica successfully from ArcMap using the create replica geoprocessing tool. Script only works for SDE creds. We need other users to be able to replicate their own versions.
Software versions -- ArcGIS Desktop 10.6 | SQL Server 2012
Error:
  File "C:\Users\jnmiller\Desktop\GEONET.py", line 41, in <module>
    initial_sender, expand, reuse_schema, get_related, replica_geometry, archiving)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.6\ArcPy\arcpy\management.py", line 960, in CreateReplica
    raise e
ExecuteError: ERROR 000582: Error occurred during execution.
Failed to execute (CreateReplica).‍‍‍‍‍‍‍
Script:
# http://desktop.arcgis.com/en/arcmap/10.3/tools/data-management-toolbox/create-replica.htm
# Description: Create a checkout to a file GDB
# Import system modules
import arcpy
from arcpy import env
#get list of versions that will be checked out
version_list = "GIS"
#specify the checkout number for version & GDB naming
checkout_number = 1
#specify folder location and file name for checkout
working_folder = r"C:\\"
working_file = "Test_%s_v%s.gdb" % (version_list, checkout_number)
# Set workspace
env.workspace = r"Database Connections\NEO.sde"
# Set local variables
in_data = ["ArchivedProposedMainline"]
replica_type = "CHECK_OUT"
output_workspace = "%s\%s" % (working_folder, working_file)
replica_name = "MyReplica_%s_v%s" % (version_list, checkout_number) # This creates the replica in the GDB manager
access_type = "FULL" # Supports complex types (topologies and geometric networks) and requires the data to be versioned.
initial_sender = "PARENT_DATA_SENDER"
expand = "USE_DEFAULTS"
reuse_schema = "DO_NOT_REUSE"
get_related = "GET_RELATED"
replica_geometry = ""
archiving = "DO_NOT_USE_ARCHIVING"
#create the empty GDB for checkout
arcpy.CreateFileGDB_management(working_folder, working_file)
# Execute CreateReplica
arcpy.CreateReplica_management(in_data, replica_type, output_workspace, replica_name, access_type, \
JoeBorgione
A couple things jump out at me:
line 15:  the reason you use r is so you don't need to escape the slash:
my_path_variable = r'C:\'
I think the extra slash may be bombing in line 26
At line 23, you set in_data as a list: why is that?  It may part of your problem as well.
The error description indicates you are not providing the proper parameters to arcpy.CreateReplica_management():
000582: Error occurred during execution.—Help | ArcGIS Desktop
