using shape_length for the indicator widget
6625
6
08-07-2018 10:52 AM
KevinBrock3
I am trying to display the total length of utility pipes by using the indicator widget and using the sum statistic of the shape_length field, I am given an error with the data by trying this, and I am wondering if it is even possible to use this field for statistics, and if not, what my other options are.
MikeOnzay
I happened to have the same question today. I used a factor of 0.000189394 to convert feet to miles. I left the offset at zero. I'm creating a gauge that shows the number of feet of sewer pipe inspected to the total number of miles that should be inspected in one year.
To figure out the conversion factor I googled conversion factor feet to miles
KevinBrock3
Were you able to use shape_length as a statistic field for your gauge? I am trying to just show the length of sewer pipe in the region in miles with the indicator widget, I figured this would be simple in OD, but its been more complicated than I thought.
MikeOnzay
No. The source is actually a survey123 hosted feature service. When the form is opened from a map the shape_length value is passed into a hidden field.
AndresCastillo
Hi Kevin,
Please see my reply below from:
https://community.esri.com/thread/116675
Andres Castillo@ Mike Liska on Mar 27, 2019 8:46 AM
I believe that in order to see the Shape.STLength() field, it needs to be a map service.
This is because if you inspect the fields that display at the rest end point of a map service vs feature service, you will notice that the feature service does not list Shape.STLength() as part of its' available fields.
If it is a map service, then you will be able to do what Alexander Baker mentioned above.
Here are some other threads talking about this:
AGO Operations Dashboard - Chrome vs IE, SHAPE.STLength() field, multi-condition variables   (This one says that the error is no longer an issue.)
Operations Dashboard - use shape_length field?
KrystalPhaneuf2
I've tried using SHAPE.LEN from both a feature layer and a map image layer and both give the same "Cannot Access Data" error.  We had to create a spatial view of our SDE data and add a length column using ST_Length().  This is in Enterprise 10.6.1.  Hopefully ESRI figures out this bug in 10.7 or 10.7.1.
Clubdebambos
MVP Regular Contributor
Currently at 11.2 and it doesn't seem to be fixed for Feature Layer or Map Image Layer 😵
~ learn.finaldraftmapping.com
