Field name too long
3694
5
08-03-2018 03:26 AM
JürgenBiendara1
When trying to publish a survey I get this error message:
It reads:
This survey cannot be published - the field name aiq_surface_preparation_adequate in anomaly_inspection_repeat is too long (32) for Portal; the maximum length is 32 characters.
If the maximum length for a field name is 32 characters, than why doesn't my field name (consisting of 32 characters) pass the validation?
Thank you very much, best regards,
Jürgen
DanPatterson_Retired
drop a letter and if it works, then this should be reported as a documentation error
(the maximum length must be less than 32 characters)
or an annoying bug.  I do suspect that this hasn't been notices because most users' field naming lengths would be much less than this threshold
JürgenBiendara1
Dropping one letter makes it work. Nevertheless, it seems to be a bug, either in the documentation AND in the error message or in the implementation.
Make sure you report it, or it won't get addressed.
in the interim you could change a synonym ie ...'adequate' to 'enough'
JamesTedrick
Esri Esteemed Contributor
Hi Jürgen,
It appears the error statement was mistranslated - the English version of the statement is:
The field name____ in _____ is too long (##) for Portal, must be less 32 characters
JürgenBiendara1
Hi James,
I reported this to Esri Germany Hotline.
