Error "Cannot open File.." happening for Add Attachments?
3600
07-26-2018 01:03 PM
JRAdams
ArcMap 10.6
Trying to use the tool,add attachments, keep getting the Error "Cannot open File D:\Pictures_...\filename"
Have generated match table
The path name is correct, the match field is correct
Have been at this for hours. Successfully used this tool last week, no problems.
Any help is greatly appreciated!!
MichaëlSt-Pierre
Same here but I found a work around. When generating your Attachment Match Table, try not to check the "Store Relative Path" box. Try Again. Make sure you verify your results at the proper Version Level.
SarahHampton1
Your match table has to be inside the same geodatabase as the feature class you are adding attachments to.
