Not Allow to Install Second Web Adapter (IIS) on Same machine
1905
7
06-26-2018 05:32 AM
VinodBorkar1
I am trying to Install ArcGIS Web Adapter 10.5.1 on Window Server 2012 R2 but its allow to Install on one webadapter.
When trying to Install second Web Adapter on same machine its not allow to Install , Its given only Modify or Remove window. not moving to install second web adapter for Server or Portal, Its strange behavior.
Please suggest .
VinodBorkar1
Second Web Adapter Installation Window
MirHashmi
Vinod, Your issue looks similar to a previous thread here.
VinodBorkar1
Thanks for your reply,
Great workaround!
It is very much useful for me.
Luis_DiegoVargas1
Hello Vinod,
You can try to make an installation from the command line, you only have to indicate the website, the port, the path where the installers are located and the Web Adaptor name.
Example.
CDM <path>
setup.exe /qb VDIRNAME=arcgis WEBSITE_ID=1 PORT=443
More nfo >
Regards.
VinodBorkar1
Thank you for your reply.
I have tried a given solutions but its not working.
still facing same issue.
VinodBorkar1
Try on other machine facing same issue.
DennisSmith
Is the machine in question a domain controller by chance?
