Are patches for ArcGIS Server and /or Portal cummulative?
1033
07-26-2018 08:14 AM
Jay_Gregory
Details:
Hi, I am planning on installing the Home Application Display patch (https://support.esri.com/en/download/7615) on my Portal 10.4 instance.
At the bottom of the patch page, it says:
"To avoid conflicts the 10.4 version also addresses:
BUG-000099447 - Unable to upload files or create groups in the Portal home application after updating the browser to Firefox 49, Chrome 54, or Safari 10.
BUG-000098559 – Un-validated redirect in Portal for ArcGIS.
BUG-000098482 - Cross-site scripting (XSS) issue in Portal for ArcGIS.
BUG-000098118 - Portal for ArcGIS exposes internal information.
BUG-000098025 - Bypass of URL redirection rule in Portal for ArcGIS.
BUG-000096571 - The secure attribute is not present on a cookie in Portal for ArcGIS.
BUG-000096570 - Reflected cross-site scripting (XSS) is possible in Portal for ArcGIS.
BUG-000094214 - Unable to import ArcGIS Pro entitlements to Portal for ArcGIS 10.4.
BUG-000091316 - Some Portal upload operations do not validate file type correctly."
It seems like those issues listed are also fixed by https://support.esri.com/en/download/7443 (Home Application Upload Patch) and https://support.esri.com/en/download/7465 (Security 2017 Update 1 Patch). This seems like the dumb question, but if I install the Home Application Display patch, then I shouldn't have to install the other 2 patches, correct? (the language "to avoid conflicts....." seems a little strange and imprecise to me)
I haven't installed any patches yet, so am wondering if I need to install all 3 to have the issues fixed, or just the latest patch (which in this case the the Home Application Display Patch)
Thanks!
DennisSmith
Thanks for the question. The ArcGIS patches are accumulative as new ones are created. Typically in your scenario you can install the latest patch and be ok.
DennisSmith
