Python routine to calculate MODIS NDVI anomaly
11394
44
06-14-2018 05:38 AM
LuizVianna
Xander Bakker
Python script to calculate NDVI anomalies
https://geonet.esri.com/people/xander_bakker‌
I´d like to automate all my workflow, from downloaded original raster datasets to anomaly calculator:
3 years data and folder structure can be downloaded here.
Question 1: What is the best option: to run separated scripts or create a unique code?
Question 2: How to translate the model builder to python script (Python script 2)?
Question 3: If the best option is to run separated, how to make it in a logical sequence (script 1 -> script 2 -> script 3)
Summary workflow:
  1. Select and download NDVI filtered raster datasets;
    1. Store downloaded original raster datasets at X:\Modis250\Originais\
    2. Organizing files and folders: (Python script 1)
    3. Rename original raster datasets (MODIS.ndvi.YYYYjjj.yL6000.BOKU.tif) to filename standard “ndvi_YYYY_dec_dd.tif”, where “YYYY” is the year, “jjj” is the Julian day and “dd” is the decade (ten days period).
    4. Transfer renamed files from X:\Modis250\Originais to X:\Modis250\NDVI10dias
  2. Pre-processing raster datasets: (Python script 2)
    1. Project renamed raster datasets ("ndvi_YYYY_dec_dd.tif") from Lat/Lon WGS 1984 to Lat/Lon SIRGAS2000 using "SAD_1969_To_WGS_1984_14 + SAD_1969_To_SIRGAS_2000_1" geographic transformation.
    2. Overwrite spurious data values: NDVI = Con("%NDVI%"<1,0,Con("%NDVI%">9998,9999,"%NDVI%"))
    3. Standardize raster datasets: NDVI = (NDVI – Mean(NDVI))/Std(NDVI)
    4. Scale raster datasets to 0 – 100: NDVI = ((NDVI-Min(NDVI))/(Max(NDVI)-Min(NDVI)) * 100
    5. Mask standardized raster datasets by the area of interest (X:\Modis250\SRTM\mde_sc_90.tif) and output to X:\Modis250\NDVI_10dias_norm
  3. Processing data (Python script 3)
    1. Calculate NDVI mean for each decadal: mean_dec_dd.tif = MEAN (ndvi_YYY1_dec_dd.tif, ndvi_YYY2_dec_dd.tif, ndvi_YYY3_dec_dd.tif,…)
    2. Calculate NDVI anomaly for each year by decade: anom_yyyy_dec_dd.tif = ndvi_YYYY_dec_dd.tif - mean_dec_dd.tif
Python scripts 1 and 3 are working. The scrip 2 (Pre-processing) is a model in a toolbox.
Python script 1: written by myself, maybe need to be improved!
#Rename original files
import arcpy, datetime, glob, os
arcpy.env.workspace=r'O:\Modis250\Originais'
infolder='O:\Modis250\Originals'
outfolder='O:\Modis250\NDVI_10dias'
list1=arcpy.ListRasters("*.tif")
list1.sort()
for raster in list1:
     source_path = os.path.join(infolder, raster)
     oldFilename=raster
     dd = int(oldFilename[15:18])
     if dd < 11: dd = 1
     elif dd < 21: dd = 2
     elif dd < 31: dd = 3
     elif dd < 41: dd = 4
     elif dd < 51: dd = 5
     elif dd < 61: dd = 6
     elif dd < 71: dd = 7
     elif dd < 81: dd = 8
     elif dd < 91: dd = 9
     elif dd < 101: dd = 10
     elif dd < 111: dd = 11
     elif dd < 121: dd = 12
     elif dd < 131: dd = 13
     elif dd < 141: dd = 14
     elif dd < 151: dd = 15
     elif dd < 161: dd = 16
     elif dd < 171: dd = 17
     elif dd < 181: dd = 18
     elif dd < 191: dd = 19
     elif dd < 201: dd = 20
     elif dd < 211: dd = 21
     elif dd < 221: dd = 22
     elif dd < 231: dd = 23
     elif dd < 241: dd = 24
     elif dd < 251: dd = 25
     elif dd < 261: dd = 26
     elif dd < 271: dd = 27
     elif dd < 281: dd = 28
     elif dd < 291: dd = 29
     elif dd < 301: dd = 30
     elif dd < 311: dd = 31
     elif dd < 321: dd = 32
     elif dd < 331: dd = 33
     elif dd < 341: dd = 34
     elif dd < 351: dd = 35
     else: dd = 36
     dd = str(dd)
     newFilename="ndvi_" + oldFilename[11:15] + "_dec_" + dd + ".tif"
     destination_path=os.path.join(outfolder, newFilename)
     os.rename(source_path, destination_path)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Model Builder -> Python script 2
Python script 3: Python script to calculate NDVI anomalies
def main():
    import arcpy
    import os
    # Check out SA license
    arcpy.CheckOutExtension("spatial")
    # settings
    ws_norm = r'D:\Modis250\NDVI_10dias_norm'
    ws_mean = r'D:\Modis250\NDVI_10dias_mean'
    ws_anom = r'D:\Modis250\NDVI_10dias_anom'
    # create a list of all raster in norm folder
    arcpy.env.workspace = ws_norm
    lst_ndvi_ras = arcpy.ListRasters()
     lst_ndvi_ras.sort()
    print ("lst_ndvi_ras: {}".format(lst_ndvi_ras))
    # get list of years
    decades = GetListOfDecades(lst_ndvi_ras)
     decades.sort()
    print ("decades: {}".format(decades))
    # loop through each year
    for decade in decades:
        # Get rasters for given year
        lst_ndvi_decade = GetListOfRasterForGivenDecade(lst_ndvi_ras, decade)
        print("lst_ndvi_decade: {}".format(lst_ndvi_decade))
        # calculate mean raster for decade
        lst_ndvi_decade_paths = [os.path.join(ws_norm, r) for r in lst_ndvi_decade]
        print("lst_ndvi_decade_paths: {}".format(lst_ndvi_decade_paths))
        mean_ras = arcpy.sa.CellStatistics(lst_ndvi_decade_paths, "MEAN", "DATA")
        # store mean ras for decade
        # mean_dec_d_.tif
        out_name_mean = "mean_dec_{}.tif".format(decade)  ###
        out_name_path_mean =  os.path.join(ws_mean, out_name_mean)
        print ("out_name_path_mean: {}".format(out_name_path_mean))
        mean_ras.save(out_name_path_mean)
        # loop through each raster in decade
        for ndvi_ras in lst_ndvi_decade:
            # calculate anom for each raster in decade
            # anom_2002_dec_1.tif = norm_ndvi_2002_dec_1.tif - mean_dec_1_.tif;
            print ("ndvi_ras: {}".format(ndvi_ras))
            # minus_ras = arcpy.sa.Minus(ndvi_ras, out_name_path_mean)
            out_name_path_norm = os.path.join(ws_norm, ndvi_ras)
            minus_ras = arcpy.Raster(out_name_path_mean) - arcpy.Raster(out_name_path_norm)
            # store anom raster
            out_name_anom = ndvi_ras.replace("norm_ndvi", "anom")
            out_name_path_anom = os.path.join(ws_anom, out_name_anom)
            minus_ras.save(out_name_path_anom)
            print ("out_name_path_anom: {}".format(out_name_path_anom))
    # return SA license
    arcpy.CheckInExtension("spatial")
def GetListOfDecades(lst):
    # norm_ndvi_yyyy_dec_d.tif
    lst1 = list(set([r.split("_")[4] for r in lst]))
    return [r.split('.')[0] for r in lst1]
def GetListOfRasterForGivenDecade(lst, decade):
    lst1 = []
    search = "_{}.tif".format(decade)
    for r in lst:
        if search in r.lower():
            lst1.append(r)
    return lst1
if __name__ == '__main__':
    main()
LuizVianna
Python routine to calculate MODIS NDVI anomaly:
Xander Bakker
modis‌ndvi calculation ndvi
Summary workflow:
def main():
     import arcpy
     import os
     import shutil
     ws_in = r'D:\Modis250\Originais'
     ws_out = r'D:\Modis250\NDVI_10dias'
     arcpy.env.workspace = ws_in
     lst_ras = arcpy.ListRasters("*.tif")
     for ras_name in sorted(lst_ras):
          # MODIS.ndvi.YYYYjjj.yL6000.BOKU.tif
          in_name_path = os.path.join(ws_in, ras_name)
          y = ras_name[11:15]
          j = int(ras_name[15:18])
          d = GetDecadeFromJulian(int(y), j)
          out_name = "ndvi_{}_dec_{}.tif".format(y, d)
          out_name_path = os.path.join(ws_out, out_name)
          #os.rename(in_name_path, out_name_path)
          shutil.move(in_name_path, out_name_path)
          print (out_name + " renamed")
def GetDecadeFromJulian(year, j):
     import datetime
     date = datetime.datetime(year-1, 12, 31) + datetime.timedelta(j)
     m = (date.month - 1) * 3
     if date.day <= 10:
          d = 1
     elif date.day <= 20:
          d = 2
     else:
          d = 3
     return m + d
    main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
  1. Pre-processing raster datasets: (Python script 2)
def main():
     import arcpy
     import os
     # Set Geoprocessing environments
     ws_scr = r'D:\Modis250\Temp' #Scratch workspace
     ws_in = r'D:\Modis250\NDVI_10dias' #Input workspace
     ws_out = r'D:\Modis250\NDVI_10dias_norm' #Output workspace
     mask = r'D:\Modis250\SRTM\mde_sc_90.tif' #Raster used as mask
     arcpy.env.scratchWorkspace = ws_scr
     lst_ras.sort()
    # Pre-processing original rasters
     for raster1 in lst_ras:
          print ("Processing: " + raster1)
          #outRaster1= Original raster projected from CGS-WGS1964 to CGS-SIRGAS-2000
          outRaster1 = os.path.join(ws_scr, "rep_{}".format(raster1))  # Temporary file
          arcpy.ProjectRaster_management(raster1, outRaster1,"GEOGCS['GCS_SIRGAS_2000',DATUM['D_SIRGAS_2000',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]", "NEAREST", "1.8000795216263E-03 1.80029836029412E-03", "'SAD_1969_To_WGS_1984_14 + SAD_1969_To_SIRGAS_2000_1'", "", "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
          print ("rep_{}".format(raster1) + " projected")
          #outRaster2 = outRaster1 masked by Area of Interest (AOI)
          outRaster2 = arcpy.sa.ExtractByMask(outRaster1, mask)  # Temporary file
          outRaster2.save(os.path.join(ws_scr, "mask_{}".format(raster1)))
          print ("mask_{}".format(raster1) + " masked")
          #outRaster3 = Overwrited spurious data values from outRaster2
          outRaster3 = arcpy.sa.Con(outRaster2 < 1, 0, arcpy.sa.Con(outRaster2 > 9998, 9999, outRaster2))  # Temporary file
          outRaster3.save(os.path.join(ws_scr, "aju_{}".format(raster1)))
          print ("aju_{}".format(raster1) + " ajusted")
          #outRaster4 = Standardized outRaster3
          #ras_mean = arcpy.GetRasterProperties_management(outRaster3, "MEAN")
          #ras_std = arcpy.GetRasterProperties_management(outRaster3, "STD")
          ras_mean = float(arcpy.GetRasterProperties_management(outRaster3, "MEAN").getOutput(0))
          ras_std = float(arcpy.GetRasterProperties_management(outRaster3, "STD").getOutput(0))
          outRaster4 = ((outRaster3-ras_mean)/ras_std)  # Temporary file
          outRaster4.save(os.path.join(ws_scr, "ras_std_{}".format(raster1)))
          print ("ras_std_{}".format(raster1) + " standardized")
          #outRaster = Final raster scaled to 0 -100
          #ras_max = arcpy.GetRasterProperties_management(outRaster4, "MAXIMUM")
          #ras_min = arcpy.GetRasterProperties_management(outRaster4, "MINIMUM")
          ras_max = float(arcpy.GetRasterProperties_management(outRaster4, "MAXIMUM").getOutput(0))
          ras_min = ras_min = float(arcpy.GetRasterProperties_management(outRaster4, "MINIMUM").getOutput(0))
          outRaster = ((outRaster4-ras_min)/(ras_max-ras_min) * 100)  # Final result
          outRaster.save(os.path.join(ws_out, "norm_{}".format(raster1)))
          print ("norm_{}".format(raster1) + " processed")
    main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
  1. Processing data (Python script 3)
def main():
     import arcpy
     import os
     # settings
##    ws_norm = r'C:\GeoNet\Modis250\NDVI_10dias_norm'
##    ws_mean = r'C:\GeoNet\Modis250\NDVI_10dias_mean'
##    ws_anom = r'C:\GeoNet\Modis250\NDVI_10dias_anom'
     #print ("Raster list: {}".format(lst_ndvi_ras))
     # get list of years
     decades.sort()
     #print ("Decades list: {}".format(decades))
          print("Decade by year list: {}".format(lst_ndvi_decade))
          #print("lst_ndvi_decade_paths: {}".format(lst_ndvi_decade_paths))
          # mean_dec_d_.tif
          print ("Mean raster: {}".format(out_name_mean))
               print ("Processing: {}".format(ndvi_ras))
               minus_ras = arcpy.Raster(out_name_path_norm) - arcpy.Raster(out_name_path_mean)
               # store anom raster
               print ("Anom: {}".format(out_name_path_anom))
     # return SA license
     lst1 = []
     for r in lst:
               lst1.append(r)
     return lst1
     main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Batch file to run on prompt:
@ECHO OFF
REM Runs NDVI anomaly scripts
ECHO Backup original files
xcopy D:\Modis250\Originais\*.tif D:\Modis250\Originais_bkp /a /c /i /y /z
PAUSE
ECHO Selecting decade and renaming original files to "ndvi_YYYY_dec_dd.tif" standard.
C:\Python27\ArcGIS10.5\Python.exe D:\Modis250\Python\Script1.py
ECHO NDVI files renamed, hit enter to pre-processing data.
PAUSE
ECHO Projecting, removing spurious data, standardizing and scaling ndvi decade files to 0-100.
C:\Python27\ArcGIS10.5\Python.exe D:\Modis250\Python\Script2.py
ECHO NDVI pre-processed, hit enter to calculate anomalies.
PAUSE
ECHO Calculating decade anomalies.
C:\Python27\ArcGIS10.5\Python.exe D:\Modis250\Python\Script3.py
Del D:\Temp /s
Del D:\NDVI_10dias /s
ECHO Done.
PAUSE‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
XanderBakker
Esri Esteemed Contributor
Let's try and do this in parts.
You can work with a single script that does all 3 steps, but it might be better to break it up in parts(as you did). This way you can check the intermediate results and run parts separately and also reuse parts for other workflows.
You can export the Model to a Python script, but that probably results in some really ugly code. It is better to rewrite the model into a new script. This also allows for some additional checks that might not be easy to do inside a model.
Depends. As I mentioned above, it may be easier to run parts separately and do some (manual) checks between the steps to be sure things go right. When you have tested thoroughly, you can call the scripts from a "master" script and run the entire process. Question: how often do you plan to run this script? Does the input data change?
I think that the first script could be rewritten like this (untested):
def main():
    import arcpy
    import os
    ws_in = 'O:\Modis250\Originals'
    ws_out = 'O:\Modis250\NDVI_10dias'
         d = GetDecadeFromJulian(j)
         out_name = "ndvi_{}_dec_{}.tif".format(j, d)
def GetDecadeFromJulian(j):
    d =  (j+1 - ((j-1) % 10)) / 10 + 1
    return str(d) if d < 37 else '36'
    main()
LuizVianna
The script 1 worked, however the output name is wrong: The names should be "ndvi_yyyy_dec_d.tif" where "yyyy" is the year (from the input file name (MODIS.ndvi.YYYYjjj.yL6000.BOKU.tif ) and "d" the decade. Why the ".2" after the decade number in the outputs? If there are more then one input file for decade, de code shoud overwrite the first.
LuizVianna
The first process will be runned one time for all the past years files (from 2000 to today). After that, the script will be runned every ten days period (decade). The new input (original file "MODIS.ndvi.YYYYjjj.yL6000.BOKU.tif") will be pre-processed and the result will be added to the list of standardized and scaled (0-100) raster datasets, to calculate the anomaly for the last decade in current year. It is a continous process.
As the name of the original file have the "YYYYjjj" format, is it possible to rename the files considering the leap years, according to the table below?
DecadeDatejulian day in common yearjulian day in leap year
101/01 to 01/101010
201/11 to 01/202020
301/21 to 01/313131
402/01 to 02/104141
502/11 to 02/205151
602/21 to 02/28-295960
703/01 to 03/106970
803/11 to 03/207980
903/21 to 03/319091
1004/01 to 04/10100101
1104/11 to 04/20110111
1204/21 to 04/30120121
1305/01 to 05/10130131
1405/11 to 05/20140141
1505/21 to 05/31151152
1606/01 to 06/10161162
1706/11 to 06/20171172
1806/21 to 06/30181182
1907/01 to 07/10191192
2007/11 to 07/20201202
2107/21 to 07/31212213
2208/01 to 08/10222223
2308/11 to 08/20232233
2408/21 to 08/31243244
2509/01 to 09/10253254
2609/11 to 09/20263264
2709/21 to 09/30273274
2810/01 to 10/10283284
2910/11 to 10/20293294
3010/21 to 10/31304305
3111/01 to 11/10314315
3211/11 to 11/20324325
3311/21 to 11/30334335
3412/01 to 12/10344345
3512/11 to 12/20354355
3612/21 to 12/31365366
XanderBakker
This would require changing the function to get the decade like this:
    import datetime
    date = datetime.datetime(year, 1, 1) + datetime.timedelta(j)
    if date.day <= 10:
        d = 1
        d = 2
    else:
        d = 3
    return m + d
Both year and Julian (j) should be provided as numeric value.
LuizVianna
Error running at ArcGisPro:
File "<string>", line 40, in <module>
File "<string>", line 13, in main
TypeError: 'NoneType' object is not iterable
in code:
def main():
    import arcpy
    import os
    ws_in = r'D:\Modis250\Originals'
#def GetDecadeFromJulian(j):
    #d =  (j+1 - ((j-1) % 10)) / 10 + 1
    #return str(d) if d < 37 else '36'
    import datetime
    if date.day <= 10:
        d = 1
        d = 2
    else:
        d = 3
    return m + d
    main()
XanderBakker
It seems you are missing some code:
def main():
    import arcpy
    import os
         y = ras_name[11:15]
    import datetime
    if date.day <= 10:
        d = 1
        d = 2
    else:
        d = 3
    return m + d
    main()
LuizVianna
Same error for your code:
File "<string>", line 37, in <module>
LuizVianna
Problem was in line 7: Originals -> Originais
The script runns, however does´t overwrite the output files: If there are more than one tif per decade, the higher julian day should represent the decade.
File "<string>", line 22, in main
FileExistsError: [WinError 183] Não é possível criar um arquivo já existente: 'D:\\Modis250\\Originais\\MODIS.ndvi.2002017.yL6000.BOKU.tif' -> 'D:\\Modis250\\NDVI_10dias\\ndvi_2002_dec_2.tif'
Does the code considered the two first files as belonging to decade two?
XanderBakker
You're using "os.rename" and on Windows if the destination exists, it will throw an error.
