Python routine to calculate MODIS NDVI anomaly
15746
44
06-14-2018 05:38 AM
LuizVianna
Xander Bakker
Python script to calculate NDVI anomalies
https://geonet.esri.com/people/xander_bakker‌
I´d like to automate all my workflow, from downloaded original raster datasets to anomaly calculator:
3 years data and folder structure can be downloaded here.
Question 1: What is the best option: to run separated scripts or create a unique code?
Question 2: How to translate the model builder to python script (Python script 2)?
Question 3: If the best option is to run separated, how to make it in a logical sequence (script 1 -> script 2 -> script 3)
Summary workflow:
  1. Select and download NDVI filtered raster datasets;
    1. Store downloaded original raster datasets at X:\Modis250\Originais\
    2. Organizing files and folders: (Python script 1)
    3. Rename original raster datasets (MODIS.ndvi.YYYYjjj.yL6000.BOKU.tif) to filename standard “ndvi_YYYY_dec_dd.tif”, where “YYYY” is the year, “jjj” is the Julian day and “dd” is the decade (ten days period).
    4. Transfer renamed files from X:\Modis250\Originais to X:\Modis250\NDVI10dias
  2. Pre-processing raster datasets: (Python script 2)
    1. Project renamed raster datasets ("ndvi_YYYY_dec_dd.tif") from Lat/Lon WGS 1984 to Lat/Lon SIRGAS2000 using "SAD_1969_To_WGS_1984_14 + SAD_1969_To_SIRGAS_2000_1" geographic transformation.
    2. Overwrite spurious data values: NDVI = Con("%NDVI%"<1,0,Con("%NDVI%">9998,9999,"%NDVI%"))
    3. Standardize raster datasets: NDVI = (NDVI – Mean(NDVI))/Std(NDVI)
    4. Scale raster datasets to 0 – 100: NDVI = ((NDVI-Min(NDVI))/(Max(NDVI)-Min(NDVI)) * 100
    5. Mask standardized raster datasets by the area of interest (X:\Modis250\SRTM\mde_sc_90.tif) and output to X:\Modis250\NDVI_10dias_norm
  3. Processing data (Python script 3)
    1. Calculate NDVI mean for each decadal: mean_dec_dd.tif = MEAN (ndvi_YYY1_dec_dd.tif, ndvi_YYY2_dec_dd.tif, ndvi_YYY3_dec_dd.tif,…)
    2. Calculate NDVI anomaly for each year by decade: anom_yyyy_dec_dd.tif = ndvi_YYYY_dec_dd.tif - mean_dec_dd.tif
Python scripts 1 and 3 are working. The scrip 2 (Pre-processing) is a model in a toolbox.
Python script 1: written by myself, maybe need to be improved!
#Rename original files
import arcpy, datetime, glob, os
arcpy.env.workspace=r'O:\Modis250\Originais'
infolder='O:\Modis250\Originals'
outfolder='O:\Modis250\NDVI_10dias'
list1=arcpy.ListRasters("*.tif")
list1.sort()
for raster in list1:
     source_path = os.path.join(infolder, raster)
     oldFilename=raster
     dd = int(oldFilename[15:18])
     if dd < 11: dd = 1
     elif dd < 21: dd = 2
     elif dd < 31: dd = 3
     elif dd < 41: dd = 4
     elif dd < 51: dd = 5
     elif dd < 61: dd = 6
     elif dd < 71: dd = 7
     elif dd < 81: dd = 8
     elif dd < 91: dd = 9
     elif dd < 101: dd = 10
     elif dd < 111: dd = 11
     elif dd < 121: dd = 12
     elif dd < 131: dd = 13
     elif dd < 141: dd = 14
     elif dd < 151: dd = 15
     elif dd < 161: dd = 16
     elif dd < 171: dd = 17
     elif dd < 181: dd = 18
     elif dd < 191: dd = 19
     elif dd < 201: dd = 20
     elif dd < 211: dd = 21
     elif dd < 221: dd = 22
     elif dd < 231: dd = 23
     elif dd < 241: dd = 24
     elif dd < 251: dd = 25
     elif dd < 261: dd = 26
     elif dd < 271: dd = 27
     elif dd < 281: dd = 28
     elif dd < 291: dd = 29
     elif dd < 301: dd = 30
     elif dd < 311: dd = 31
     elif dd < 321: dd = 32
     elif dd < 331: dd = 33
     elif dd < 341: dd = 34
     elif dd < 351: dd = 35
     else: dd = 36
     dd = str(dd)
     newFilename="ndvi_" + oldFilename[11:15] + "_dec_" + dd + ".tif"
     destination_path=os.path.join(outfolder, newFilename)
     os.rename(source_path, destination_path)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Model Builder -> Python script 2
Python script 3: Python script to calculate NDVI anomalies
def main():
    import arcpy
    import os
    # Check out SA license
    arcpy.CheckOutExtension("spatial")
    # settings
    ws_norm = r'D:\Modis250\NDVI_10dias_norm'
    ws_mean = r'D:\Modis250\NDVI_10dias_mean'
    ws_anom = r'D:\Modis250\NDVI_10dias_anom'
    # create a list of all raster in norm folder
    arcpy.env.workspace = ws_norm
    lst_ndvi_ras = arcpy.ListRasters()
     lst_ndvi_ras.sort()
    print ("lst_ndvi_ras: {}".format(lst_ndvi_ras))
    # get list of years
    decades = GetListOfDecades(lst_ndvi_ras)
     decades.sort()
    print ("decades: {}".format(decades))
    # loop through each year
    for decade in decades:
        # Get rasters for given year
        lst_ndvi_decade = GetListOfRasterForGivenDecade(lst_ndvi_ras, decade)
        print("lst_ndvi_decade: {}".format(lst_ndvi_decade))
        # calculate mean raster for decade
        lst_ndvi_decade_paths = [os.path.join(ws_norm, r) for r in lst_ndvi_decade]
        print("lst_ndvi_decade_paths: {}".format(lst_ndvi_decade_paths))
        mean_ras = arcpy.sa.CellStatistics(lst_ndvi_decade_paths, "MEAN", "DATA")
        # store mean ras for decade
        # mean_dec_d_.tif
        out_name_mean = "mean_dec_{}.tif".format(decade)  ###
        out_name_path_mean =  os.path.join(ws_mean, out_name_mean)
        print ("out_name_path_mean: {}".format(out_name_path_mean))
        mean_ras.save(out_name_path_mean)
        # loop through each raster in decade
        for ndvi_ras in lst_ndvi_decade:
            # calculate anom for each raster in decade
            # anom_2002_dec_1.tif = norm_ndvi_2002_dec_1.tif - mean_dec_1_.tif;
            print ("ndvi_ras: {}".format(ndvi_ras))
            # minus_ras = arcpy.sa.Minus(ndvi_ras, out_name_path_mean)
            out_name_path_norm = os.path.join(ws_norm, ndvi_ras)
            minus_ras = arcpy.Raster(out_name_path_mean) - arcpy.Raster(out_name_path_norm)
            # store anom raster
            out_name_anom = ndvi_ras.replace("norm_ndvi", "anom")
            out_name_path_anom = os.path.join(ws_anom, out_name_anom)
            minus_ras.save(out_name_path_anom)
            print ("out_name_path_anom: {}".format(out_name_path_anom))
    # return SA license
    arcpy.CheckInExtension("spatial")
def GetListOfDecades(lst):
    # norm_ndvi_yyyy_dec_d.tif
    lst1 = list(set([r.split("_")[4] for r in lst]))
    return [r.split('.')[0] for r in lst1]
def GetListOfRasterForGivenDecade(lst, decade):
    lst1 = []
    search = "_{}.tif".format(decade)
    for r in lst:
        if search in r.lower():
            lst1.append(r)
    return lst1
if __name__ == '__main__':
    main()
XanderBakker
Esri Esteemed Contributor
Perhaps "shutil.move()" could do the trick. See python - Force Overwrite in Os.Rename - Stack Overflow
LuizVianna
Script 1 working now! Thank you!
Now, can you please help me with the script 2?
  1. Pre-processing raster datasets: (Python script 2)
    1. Project the renamed raster datasets in "X:Modis250\NDVI_10dias" as ("ndvi_YYYY_dec_dd.tif") from Lat/Lon WGS 1984 to Lat/Lon SIRGAS2000 using "SAD_1969_To_WGS_1984_14 + SAD_1969_To_SIRGAS_2000_1" geographic transformation.
This is the script from Model Builder:
# -*- coding: utf-8 -*-
# Script2_Model_Builder.py
# Created on: 2018-06-14 17:09:24.00000
#   (generated by ArcGIS/ModelBuilder)
# Usage: Script2_Model_Builder <InFolder> <Wildcard> <Name> <Mask> <OutFolder1> <OutFolder2> <Raster_Format>
# Description:
# Import arcpy module
import arcpy
# Load required toolboxes
arcpy.ImportToolbox("Model Functions")
# Script arguments
InFolder = arcpy.GetParameterAsText(0)
if InFolder == '#' or not InFolder:
    InFolder = "O:\\Modis250\\NDVI_10dias" # provide a default value if unspecified
Wildcard = arcpy.GetParameterAsText(1)
Name = arcpy.GetParameterAsText(2)
if Name == '#' or not Name:
    Name = "ndvi_2001_dec_10" # provide a default value if unspecified
Mask = arcpy.GetParameterAsText(3)
if Mask == '#' or not Mask:
    Mask = "O:\\Modis250\\SRTM\\mde_sc_90.tif" # provide a default value if unspecified
OutFolder1 = arcpy.GetParameterAsText(4)
if OutFolder1 == '#' or not OutFolder1:
    OutFolder1 = "O:\\Modis250\\Temp\\mask_%Name%" # provide a default value if unspecified
OutFolder2 = arcpy.GetParameterAsText(5)
if OutFolder2 == '#' or not OutFolder2:
    OutFolder2 = "O:\\Modis250\\NDVI_10dias_norm\\norm_%Name%" # provide a default value if unspecified
Raster_Format = arcpy.GetParameterAsText(6)
if Raster_Format == '#' or not Raster_Format:
    Raster_Format = "TIF" # provide a default value if unspecified
# Local variables:
Recursive = "false"
Raster = "O:\\Modis250\\NDVI_10dias\\ndvi_2001_dec_10.tif"
NDVI_Project = "O:\\Modis250\\Temp\\ndvi_2001_dec_10_ProjectRast1.tif"
mean = "7770.0395015223"
std = "924.13000791157"
RDS_STD = "O:\\Modis250\\Temp\\%Name%_std.tif"
min = "-8.4079504013062"
max = "2.4119555950165"
# Set Geoprocessing environments
arcpy.env.scratchWorkspace = "O:\\Modis250\\Temp"
arcpy.env.workspace = "O:\\Modis250\\MODIS_13Q1_V6_filtered"
# Process: Iterate Rasters
arcpy.IterateRasters_mb(InFolder, Wildcard, Raster_Format, Recursive)
# Process: Project Raster
arcpy.ProjectRaster_management(Raster, NDVI_Project, "GEOGCS['GCS_SIRGAS_2000',DATUM['D_SIRGAS_2000',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]", "NEAREST", "1.8000795216263E-03 1.80029836029412E-03", "'SAD_1969_To_WGS_1984_14 + SAD_1969_To_SIRGAS_2000_1'", "", "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
# Process: Raster Calculator
tempEnvironment0 = arcpy.env.mask
arcpy.env.mask = Mask
arcpy.gp.RasterCalculator_sa("Con(\"%NDVI_Project%\"<1,0,Con(\"%NDVI_Project%\">9998,9999,\"%NDVI_Project%\"))", OutFolder1)
arcpy.env.mask = tempEnvironment0
# Process: Get Raster Properties
arcpy.GetRasterProperties_management(OutFolder1, "MEAN", "")
# Process: Get Raster Properties (2)
arcpy.GetRasterProperties_management(OutFolder1, "STD", "")
# Process: Raster Calculator (2)
arcpy.gp.RasterCalculator_sa("(\"%OutFolder1%\" - float(%mean%)) / float(%std%)", RDS_STD)
# Process: Get Raster Properties (4)
arcpy.GetRasterProperties_management(RDS_STD, "MINIMUM", "")
# Process: Get Raster Properties (3)
arcpy.GetRasterProperties_management(RDS_STD, "MAXIMUM", "")
# Process: Raster Calculator (3)
arcpy.gp.RasterCalculator_sa("(\"%RDS_STD%\" - float(%min%)) / (float(%max%) - float(%min%)) * 100", OutFolder2)
XanderBakker
I notice in your description that you apply the mask after the min, max, mean and std have been defined. These values will be different before and after applying the mask. Is using the values before applying the mask correct?
You may have noticed that the exported script contains some "anomalies". The use of an iteration in model builder normally does not get exported correctly into the output script. As you can see there are local variables (mean, std, min, max, even the last two overwrite exiting functions) that are defined before the iteration and would be used inside the iteration (if the code would run). Don't get me wrong, in Model Builder it will work correctly, but as script it will not work.
So this requires a different approach. As mentioned in other discussions, if normally takes more time to understand a model builder exported script and adjust it then it will take to start from scratch.
LuizVianna
You are right! I´m trying to write a new code to apply the mask before the statistics and after projecting, but some issues are happening.
Te error:
File "<string>", line 48, in <module>
File "<string>", line 26, in main
NameError: name 'ExtractByMask' is not defined
The line 4 is not running also, is it important for the ExtractByMask?
The new code:
def main():
     import arcpy
     from arcpy import env
     #from arcpy.sa import *
     import os
     ws_scr = r'D:\Modis250\Temp' #Scratch workspace
     ws_in = r'D:\Modis250\NDVI_10dias' #Input workspace
     ws_out = r'D:\Modis250\NDVI_10dias_norm' #Output workspace
     mask=r'D:\Modis250\SRTM\mde_sc_90.tif' #Raster used as mask
     arcpy.env.scratchWorkspace = ws_scr
     arcpy.env.workspace = ws_in
     lst_ras = arcpy.ListRasters("*.tif")
     # Reproject original rasters
     for raster1 in lst_ras:
          print ("Processing: " + raster1)
          outRaster1 = ws_scr+"\\rep_"+raster1 #Temporary file
          arcpy.ProjectRaster_management(raster1, outRaster1,"GEOGCS['GCS_SIRGAS_2000',DATUM['D_SIRGAS_2000',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]", "NEAREST", "1.8000795216263E-03 1.80029836029412E-03", "'SAD_1969_To_WGS_1984_14 + SAD_1969_To_SIRGAS_2000_1'", "", "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
          print (outRaster1 + " projected")
          #outRaster2 = ws_scr+"\\mask_"+raster1
          outRaster2 = ExtractByMask(outRaster1, mask) #Temporary file
          outRaster2.save(ws_scr+"\\mask_"+raster1)
          print (outRaster2 + " masked")
          #outRaster3 = ws_scr+"\\aju_"+raster1
          outRaster3 = Con(outRaster2<1,0,Con(outRaster2>9998,9999,outRaster2))#Temporary file
          outRaster3.save(ws_scr+"\\aju_"+raster1)
          print (outRaster3 + " ajusted")
          mean = arcpy.GetRasterProperties_management(outRaster3, "MEAN")
          std = arcpy.GetRasterProperties_management(outRaster3, "STD")
          outRaster4 = ((outRaster3-mean)/std)#Temporary file
          outRaster4.save(ws_scr+"\\std_"+raster1)
          print (outRaster4 + " standardized")
          max = arcpy.GetRasterProperties_management(outRaster4, "MAXIMUM")
          min = arcpy.GetRasterProperties_management(outRaster4, "MINIMUM")
          outRaster = ((outRaster4-min)/(max-min))#Final result
          outRaster.save(ws_out+"\\"+"norm_"+raster1)
          print (outRaster + " processed")
    main()
XanderBakker
Some small adjustments. Can you see where this produces an error and if anything is printed?
def main():
    import arcpy
    import os
    mask = r'D:\Modis250\SRTM\mde_sc_90.tif' #Raster used as mask
        outRaster1 = os.path.join(ws_scr, "rep_{}".join(raster1))  # Temporary file
        outRaster2 = arcpy.sa.ExtractByMask(outRaster1, mask)  # Temporary file
        outRaster2.save(os.path.join(ws_scr, "mask_{}".format(raster1)))
        outRaster3 = arcpy.sa.Con(outRaster2 < 1, 0, arcpy.sa.Con(outRaster2 > 9998, 9999, outRaster2))  # Temporary file
        outRaster3.save(os.path.join(ws_scr, "aju_{}".format(raster1)))
        outRaster4 = ((outRaster3-mean)/std)  # Temporary file
        outRaster4.save(os.path.join(ws_scr, "std_{}".format(raster1)))
        ras_max = arcpy.GetRasterProperties_management(outRaster4, "MAXIMUM")
        ras_min = arcpy.GetRasterProperties_management(outRaster4, "MINIMUM")
        outRaster = ((outRaster4-ras_min)/(ras_max-ras_min))  # Final result
        outRaster.save(os.path.join(ws_out, "norm_{}".format(raster1)))
    main()
LuizVianna
In my code, the ProjectRaster_management worked and the projected raster dataset(outRaster1) was generated. In the next step, the error occoured at "ExtractByMask".
In your code, neither the "project" step worked. The error was:
File "<string>", line 20, in main
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 9090, in ProjectRaster
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 9087, in ProjectRaster
retval = convertArcObjectToPythonObject(gp.ProjectRaster_management(*gp_fixargs((in_raster, out_raster, out_coor_system, resampling_type, cell_size, geographic_transform, Registration_Point, in_coor_system), True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000445: Extension is invalid for the output raster format.
Failed to execute (ProjectRaster).
LuizVianna
In line 19 is ".join(raster1)" or .format(raster1)?
XanderBakker
Good catch, that should be format as you mentioned.
LuizVianna
I replaced the line 19 and executed the code in both ArcGis 10.5 and ArcGis Pro. Before execute the code, I deleted all Temp files. Follow the prints and errors:
ArcGis 10.5: After run the "project" step, the system adds the rep_ndvi_2002_dec_10.tif to the ArcMap´s TOC. In the Temp workspace, two tifs were generated: "rep_ndvi_2002_dec_10.tif" and "mask_ndvi_2002_dec_10.tif", so I think that the "ExtractByMask" is working.
Processing: ndvi_2002_dec_10.tif
D:\Modis250\Temp\rep_ndvi_2002_dec_10.tif projected
Runtime error
File "c:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\sa\Functions.py", line 4329, in Plus
in_raster_or_constant2)
File "c:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\sa\Utils.py", line 53, in swapper
result = wrapper(*args, **kwargs)
File "c:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\sa\Functions.py", line 4326, in Wrapper
["Plus", in_raster_or_constant1, in_raster_or_constant2])
RuntimeError: ERROR 000732: Input Raster: Dataset masked does not exist or is not supported
ArcGisPro: In the Temp workspace, two tifs were generated: "rep_ndvi_2002_dec_10.tif" and "mask_ndvi_2002_dec_10.tif", so I think that the "ExtractByMask" is working.
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sa\Functions.py", line 4353, in Plus
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sa\Utils.py", line 53, in swapper
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sa\Functions.py", line 4350, in Wrapper
LuizVianna
Running from prompt, same error:
C:\Program Files\ArcGIS\Pro\bin\Python\Scripts>propy.bat D:\Modis250\Python\Script2_2.py
File "D:\Modis250\Python\Script2_2.py", line 48, in <module>
main()
File "D:\Modis250\Python\Script2_2.py", line 26, in main
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\sa\Functions.py", line 4353, in Plus
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\sa\Utils.py", line 53, in swapper
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\sa\Functions.py", line 4350, in Wrapper
