Python routine to calculate MODIS NDVI anomaly
15784
44
06-14-2018 05:38 AM
LuizVianna
Xander Bakker
Python script to calculate NDVI anomalies
https://geonet.esri.com/people/xander_bakker‌
I´d like to automate all my workflow, from downloaded original raster datasets to anomaly calculator:
3 years data and folder structure can be downloaded here.
Question 1: What is the best option: to run separated scripts or create a unique code?
Question 2: How to translate the model builder to python script (Python script 2)?
Question 3: If the best option is to run separated, how to make it in a logical sequence (script 1 -> script 2 -> script 3)
Summary workflow:
  1. Select and download NDVI filtered raster datasets;
    1. Store downloaded original raster datasets at X:\Modis250\Originais\
    2. Organizing files and folders: (Python script 1)
    3. Rename original raster datasets (MODIS.ndvi.YYYYjjj.yL6000.BOKU.tif) to filename standard “ndvi_YYYY_dec_dd.tif”, where “YYYY” is the year, “jjj” is the Julian day and “dd” is the decade (ten days period).
    4. Transfer renamed files from X:\Modis250\Originais to X:\Modis250\NDVI10dias
  2. Pre-processing raster datasets: (Python script 2)
    1. Project renamed raster datasets ("ndvi_YYYY_dec_dd.tif") from Lat/Lon WGS 1984 to Lat/Lon SIRGAS2000 using "SAD_1969_To_WGS_1984_14 + SAD_1969_To_SIRGAS_2000_1" geographic transformation.
    2. Overwrite spurious data values: NDVI = Con("%NDVI%"<1,0,Con("%NDVI%">9998,9999,"%NDVI%"))
    3. Standardize raster datasets: NDVI = (NDVI – Mean(NDVI))/Std(NDVI)
    4. Scale raster datasets to 0 – 100: NDVI = ((NDVI-Min(NDVI))/(Max(NDVI)-Min(NDVI)) * 100
    5. Mask standardized raster datasets by the area of interest (X:\Modis250\SRTM\mde_sc_90.tif) and output to X:\Modis250\NDVI_10dias_norm
  3. Processing data (Python script 3)
    1. Calculate NDVI mean for each decadal: mean_dec_dd.tif = MEAN (ndvi_YYY1_dec_dd.tif, ndvi_YYY2_dec_dd.tif, ndvi_YYY3_dec_dd.tif,…)
    2. Calculate NDVI anomaly for each year by decade: anom_yyyy_dec_dd.tif = ndvi_YYYY_dec_dd.tif - mean_dec_dd.tif
Python scripts 1 and 3 are working. The scrip 2 (Pre-processing) is a model in a toolbox.
Python script 1: written by myself, maybe need to be improved!
#Rename original files
import arcpy, datetime, glob, os
arcpy.env.workspace=r'O:\Modis250\Originais'
infolder='O:\Modis250\Originals'
outfolder='O:\Modis250\NDVI_10dias'
list1=arcpy.ListRasters("*.tif")
list1.sort()
for raster in list1:
     source_path = os.path.join(infolder, raster)
     oldFilename=raster
     dd = int(oldFilename[15:18])
     if dd < 11: dd = 1
     elif dd < 21: dd = 2
     elif dd < 31: dd = 3
     elif dd < 41: dd = 4
     elif dd < 51: dd = 5
     elif dd < 61: dd = 6
     elif dd < 71: dd = 7
     elif dd < 81: dd = 8
     elif dd < 91: dd = 9
     elif dd < 101: dd = 10
     elif dd < 111: dd = 11
     elif dd < 121: dd = 12
     elif dd < 131: dd = 13
     elif dd < 141: dd = 14
     elif dd < 151: dd = 15
     elif dd < 161: dd = 16
     elif dd < 171: dd = 17
     elif dd < 181: dd = 18
     elif dd < 191: dd = 19
     elif dd < 201: dd = 20
     elif dd < 211: dd = 21
     elif dd < 221: dd = 22
     elif dd < 231: dd = 23
     elif dd < 241: dd = 24
     elif dd < 251: dd = 25
     elif dd < 261: dd = 26
     elif dd < 271: dd = 27
     elif dd < 281: dd = 28
     elif dd < 291: dd = 29
     elif dd < 301: dd = 30
     elif dd < 311: dd = 31
     elif dd < 321: dd = 32
     elif dd < 331: dd = 33
     elif dd < 341: dd = 34
     elif dd < 351: dd = 35
     else: dd = 36
     dd = str(dd)
     newFilename="ndvi_" + oldFilename[11:15] + "_dec_" + dd + ".tif"
     destination_path=os.path.join(outfolder, newFilename)
     os.rename(source_path, destination_path)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Model Builder -> Python script 2
Python script 3: Python script to calculate NDVI anomalies
def main():
    import arcpy
    import os
    # Check out SA license
    arcpy.CheckOutExtension("spatial")
    # settings
    ws_norm = r'D:\Modis250\NDVI_10dias_norm'
    ws_mean = r'D:\Modis250\NDVI_10dias_mean'
    ws_anom = r'D:\Modis250\NDVI_10dias_anom'
    # create a list of all raster in norm folder
    arcpy.env.workspace = ws_norm
    lst_ndvi_ras = arcpy.ListRasters()
     lst_ndvi_ras.sort()
    print ("lst_ndvi_ras: {}".format(lst_ndvi_ras))
    # get list of years
    decades = GetListOfDecades(lst_ndvi_ras)
     decades.sort()
    print ("decades: {}".format(decades))
    # loop through each year
    for decade in decades:
        # Get rasters for given year
        lst_ndvi_decade = GetListOfRasterForGivenDecade(lst_ndvi_ras, decade)
        print("lst_ndvi_decade: {}".format(lst_ndvi_decade))
        # calculate mean raster for decade
        lst_ndvi_decade_paths = [os.path.join(ws_norm, r) for r in lst_ndvi_decade]
        print("lst_ndvi_decade_paths: {}".format(lst_ndvi_decade_paths))
        mean_ras = arcpy.sa.CellStatistics(lst_ndvi_decade_paths, "MEAN", "DATA")
        # store mean ras for decade
        # mean_dec_d_.tif
        out_name_mean = "mean_dec_{}.tif".format(decade)  ###
        out_name_path_mean =  os.path.join(ws_mean, out_name_mean)
        print ("out_name_path_mean: {}".format(out_name_path_mean))
        mean_ras.save(out_name_path_mean)
        # loop through each raster in decade
        for ndvi_ras in lst_ndvi_decade:
            # calculate anom for each raster in decade
            # anom_2002_dec_1.tif = norm_ndvi_2002_dec_1.tif - mean_dec_1_.tif;
            print ("ndvi_ras: {}".format(ndvi_ras))
            # minus_ras = arcpy.sa.Minus(ndvi_ras, out_name_path_mean)
            out_name_path_norm = os.path.join(ws_norm, ndvi_ras)
            minus_ras = arcpy.Raster(out_name_path_mean) - arcpy.Raster(out_name_path_norm)
            # store anom raster
            out_name_anom = ndvi_ras.replace("norm_ndvi", "anom")
            out_name_path_anom = os.path.join(ws_anom, out_name_anom)
            minus_ras.save(out_name_path_anom)
            print ("out_name_path_anom: {}".format(out_name_path_anom))
    # return SA license
    arcpy.CheckInExtension("spatial")
def GetListOfDecades(lst):
    # norm_ndvi_yyyy_dec_d.tif
    lst1 = list(set([r.split("_")[4] for r in lst]))
    return [r.split('.')[0] for r in lst1]
def GetListOfRasterForGivenDecade(lst, decade):
    lst1 = []
    search = "_{}.tif".format(decade)
    for r in lst:
        if search in r.lower():
            lst1.append(r)
    return lst1
if __name__ == '__main__':
    main()
LuizVianna
I write a batch file to run the scripts sequentialy. Can I insert a last line to delete all files in Temp workspace after all?
Like:
@ECHO OFF
REM Runs NDVI anomaly scripts
ECHO Selecting decade and renaming original files to "ndvi_YYYY_dec_dd.tif" standard.
C:\Python27\ArcGIS10.5\Python.exe D:\Modis250\Python\Script1.py
ECHO NDVI files renamed, hit enter to pre-processing data.
PAUSE
ECHO Projecting, removing spurious data, standardizing and scaling ndvi decade files to 0-100.
C:\Python27\ArcGIS10.5\Python.exe D:\Modis250\Python\Script2.py
ECHO NDVI pre-processed, hit enter to calculate anomalies.
PAUSE
ECHO Calculating decade anomalies.
C:\Python27\ArcGIS10.5\Python.exe D:\Modis250\Python\Script3.py
del *.* D:\Temp
ECHO Done.
PAUSE‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
XanderBakker
Esri Esteemed Contributor
I guess you could in case ArcGIS released any locks on the datasets...
LuizVianna
Python routine to calculate MODIS NDVI anomaly:
Xander Bakker
modis‌ndvi calculation ndvi
Summary workflow:
def main():
     import arcpy
     import os
     import shutil
     ws_in = r'D:\Modis250\Originais'
     ws_out = r'D:\Modis250\NDVI_10dias'
     arcpy.env.workspace = ws_in
     lst_ras = arcpy.ListRasters("*.tif")
     for ras_name in sorted(lst_ras):
          # MODIS.ndvi.YYYYjjj.yL6000.BOKU.tif
          in_name_path = os.path.join(ws_in, ras_name)
          y = ras_name[11:15]
          j = int(ras_name[15:18])
          d = GetDecadeFromJulian(int(y), j)
          out_name = "ndvi_{}_dec_{}.tif".format(y, d)
          out_name_path = os.path.join(ws_out, out_name)
          #os.rename(in_name_path, out_name_path)
          shutil.move(in_name_path, out_name_path)
          print (out_name + " renamed")
def GetDecadeFromJulian(year, j):
     import datetime
     date = datetime.datetime(year-1, 12, 31) + datetime.timedelta(j)
     m = (date.month - 1) * 3
     if date.day <= 10:
          d = 1
     elif date.day <= 20:
          d = 2
     else:
          d = 3
     return m + d
    main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
  1. Pre-processing raster datasets: (Python script 2)
def main():
     import arcpy
     import os
     # Set Geoprocessing environments
     ws_scr = r'D:\Modis250\Temp' #Scratch workspace
     ws_in = r'D:\Modis250\NDVI_10dias' #Input workspace
     ws_out = r'D:\Modis250\NDVI_10dias_norm' #Output workspace
     mask = r'D:\Modis250\SRTM\mde_sc_90.tif' #Raster used as mask
     arcpy.env.scratchWorkspace = ws_scr
     lst_ras.sort()
    # Pre-processing original rasters
     for raster1 in lst_ras:
          print ("Processing: " + raster1)
          #outRaster1= Original raster projected from CGS-WGS1964 to CGS-SIRGAS-2000
          outRaster1 = os.path.join(ws_scr, "rep_{}".format(raster1))  # Temporary file
          arcpy.ProjectRaster_management(raster1, outRaster1,"GEOGCS['GCS_SIRGAS_2000',DATUM['D_SIRGAS_2000',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]", "NEAREST", "1.8000795216263E-03 1.80029836029412E-03", "'SAD_1969_To_WGS_1984_14 + SAD_1969_To_SIRGAS_2000_1'", "", "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
          print ("rep_{}".format(raster1) + " projected")
          #outRaster2 = outRaster1 masked by Area of Interest (AOI)
          outRaster2 = arcpy.sa.ExtractByMask(outRaster1, mask)  # Temporary file
          outRaster2.save(os.path.join(ws_scr, "mask_{}".format(raster1)))
          print ("mask_{}".format(raster1) + " masked")
          #outRaster3 = Overwrited spurious data values from outRaster2
          outRaster3 = arcpy.sa.Con(outRaster2 < 1, 0, arcpy.sa.Con(outRaster2 > 9998, 9999, outRaster2))  # Temporary file
          outRaster3.save(os.path.join(ws_scr, "aju_{}".format(raster1)))
          print ("aju_{}".format(raster1) + " ajusted")
          #outRaster4 = Standardized outRaster3
          #ras_mean = arcpy.GetRasterProperties_management(outRaster3, "MEAN")
          #ras_std = arcpy.GetRasterProperties_management(outRaster3, "STD")
          ras_mean = float(arcpy.GetRasterProperties_management(outRaster3, "MEAN").getOutput(0))
          ras_std = float(arcpy.GetRasterProperties_management(outRaster3, "STD").getOutput(0))
          outRaster4 = ((outRaster3-ras_mean)/ras_std)  # Temporary file
          outRaster4.save(os.path.join(ws_scr, "ras_std_{}".format(raster1)))
          print ("ras_std_{}".format(raster1) + " standardized")
          #outRaster = Final raster scaled to 0 -100
          #ras_max = arcpy.GetRasterProperties_management(outRaster4, "MAXIMUM")
          #ras_min = arcpy.GetRasterProperties_management(outRaster4, "MINIMUM")
          ras_max = float(arcpy.GetRasterProperties_management(outRaster4, "MAXIMUM").getOutput(0))
          ras_min = ras_min = float(arcpy.GetRasterProperties_management(outRaster4, "MINIMUM").getOutput(0))
          outRaster = ((outRaster4-ras_min)/(ras_max-ras_min) * 100)  # Final result
          outRaster.save(os.path.join(ws_out, "norm_{}".format(raster1)))
          print ("norm_{}".format(raster1) + " processed")
    main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
  1. Processing data (Python script 3)
def main():
     import arcpy
     import os
     # settings
##    ws_norm = r'C:\GeoNet\Modis250\NDVI_10dias_norm'
##    ws_mean = r'C:\GeoNet\Modis250\NDVI_10dias_mean'
##    ws_anom = r'C:\GeoNet\Modis250\NDVI_10dias_anom'
     #print ("Raster list: {}".format(lst_ndvi_ras))
     # get list of years
     decades.sort()
     #print ("Decades list: {}".format(decades))
          print("Decade by year list: {}".format(lst_ndvi_decade))
          #print("lst_ndvi_decade_paths: {}".format(lst_ndvi_decade_paths))
          # mean_dec_d_.tif
          print ("Mean raster: {}".format(out_name_mean))
               print ("Processing: {}".format(ndvi_ras))
               minus_ras = arcpy.Raster(out_name_path_norm) - arcpy.Raster(out_name_path_mean)
               # store anom raster
               print ("Anom: {}".format(out_name_path_anom))
     # return SA license
     lst1 = []
     for r in lst:
               lst1.append(r)
     return lst1
     main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Batch file to run on prompt:
@ECHO OFF
ECHO Backup original files
xcopy D:\Modis250\Originais\*.tif D:\Modis250\Originais_bkp /a /c /i /y /z
PAUSE
PAUSE
PAUSE
Del D:\Temp /s
Del D:\NDVI_10dias /s
ECHO Done.
XanderBakker
Glad it works...
LuizVianna
Thank you!
Best wishes!
