Map pane navigation while editing
17000
6
06-13-2018 09:58 AM
JoeBorgione
In ArcMap it's fairly easy to move around a map while in a an edit session with a given tool active; just click on the pan tool, make your move, click back on the edit tool you were using and pick up were you left off.  All I've found so far  in Pro is to use the mouse wheel to zoom in or out; that leaves the selected edit tool.  But if I'm at the desired scale and need to pan, how do I do that?  Am I missing something obvious?
AdrianWelsh
MVP Honored Contributor
Joe,
My mouse has a scroll wheel and when I have the Select tool selected, I press and hold my scroll wheel to pan around the map.
DanPatterson_Retired
AdrianWelsh
Joe,
JoeBorgione
Awesome Adrian.  Thanks!!
AdrianWelsh
No problem! Glad it was an easy solution!
CordulaGöke
It worked for me earlier to press the scroll bar. This session in v3.2.0 it does not work any more and the map view does not have any scrollbars any more. So as written before the keyboard shortcuts do the trick now http://pro.arcgis.com/en/pro-app/help/editing/keyboard-shortcuts-for-editing.htm
BryndaHatch
the arrow keys work too
