Quality Control request for a graphic layer script snippet
3917
9
06-02-2018 11:14 PM
BrandonPrice
Can anybody find anything wrong with this? I want to check myself.
var text = new TextSymbol("Hello World");
var pt = new Point(-118.5, 34.5, map.spatialReference);
var graphic = new Graphic(pt, text);
map.graphic.show();
Thank you
RobertScheitlin__GISP
Brandon,
   Not sure what you are missing but here is a working sample:
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
    <title>Labeling features client-side</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.24/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%; width: 100%; margin: 0; padding: 0;
    </style>
   <script src="https://js.arcgis.com/3.24/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/geometry/Extent",
        "esri/geometry/Point",
        "esri/layers/FeatureLayer",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/TextSymbol",
        "esri/renderers/SimpleRenderer",
        "esri/layers/LabelClass",
        "esri/Color",
        "esri/graphic",
        "dojo/domReady!"
      ], function(Map, Extent, Point, FeatureLayer,
                  SimpleLineSymbol, SimpleFillSymbol,
                  TextSymbol, SimpleRenderer, LabelClass, Color, Graphic)
        // load the map centered on the United States
        var bbox = new Extent({"xmin": -1940058, "ymin": -814715, "xmax": 1683105, "ymax": 1446096, "spatialReference": {"wkid": 102003}});
        //create the map and set the extent, making sure to "showLabels"
        map = new Map("map", {
          extent: bbox,
          showLabels : true //very important that this must be set to true!
        // create a renderer for the states layer to override default symbology
        var statesColor = new Color("#666");
        var statesLine = new SimpleLineSymbol("solid", statesColor, 1.5);
        var statesSymbol = new SimpleFillSymbol("solid", statesLine, null);
        var statesRenderer = new SimpleRenderer(statesSymbol);
        // create the feature layer to render and label
        var statesUrl = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3";
        var states = new FeatureLayer(statesUrl, {
          outFields: ["*"]
        states.setRenderer(statesRenderer);
        // create a text symbol to define the style of labels
        var statesLabel = new TextSymbol().setColor(statesColor);
        statesLabel.font.setSize("14pt");
        statesLabel.font.setFamily("arial");
        //this is the very least of what should be set within the JSON
        var json = {
          "labelExpressionInfo": {"value": "{STATE_NAME}"}
        //create instance of LabelClass (note: multiple LabelClasses can be passed in as an array)
        var labelClass = new LabelClass(json);
        labelClass.symbol = statesLabel; // symbol also can be set in LabelClass' json
        states.setLabelingInfo([ labelClass ]);
        map.addLayer(states);
        map.on("load", function() {
          map.graphics.add(graphic);
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
Brandon,
Are you adding the graphics to the map elsewhere in your code that you are not showing here?..
BrandonPrice
I was testing this in the sandbox first. I haven't added this to my file yet. I was going to add this right after I my creation of the dynamic layers in my map.
Brandon,
   But still if you do not add the graphic to the map them how is it going to show in the map?
BrandonPrice
You are right. I will test it out.
BrandonPrice
How is this?
Brandon,
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
    </style>
    <script>
      var map;
      require([
        "esri/map",
        "esri/Color",
        "esri/graphic",
        "dojo/domReady!"
          extent: bbox,
          outFields: ["*"]
        var json = {
    </script>
  </head>
  <body>
  </body>
</html>
BrandonPrice
Thanks Robert. Would this be the best way to label something that is not in apart of a layers attribute table?
Correct
BrandonPrice
Got it. Thanks Robert.
