Euclidean Distance at the border
1246
05-30-2018 04:44 PM
VigneshP1
I have two feature classes - a firm level, point shape file and a district level, polygon shape file. Have around 12000 firms and 15 districts. I would like to find the following two things:
Question 1. Find the firms that are within 10km from the border of a district.
Question 2. Find the Euclidean distance of each firm.
When I tried to perform both these operations using some information from the past posts and some Youtube instruction videos, have encountered few issues and I am listing them below:
Issues for Question 1: I tried using "Near Tool", by selecting the Firm level, Point shape file as the Input feature and District level shape file as the Near Feature by using 10 km as the radius, but arcmap is providing me with negative (-1) district IDs which cannot be possible.
Issues for Question 2: I am unable to select two feature classes when I select the Euclidean distance tool, therefore can't use this tool at all.
Any instructions would be helpful.
Thanks.
DanPatterson_Retired
Sort of like this?
I connected the 'near' coordinates to the original point coordinates to form the lines which obviously have a distance.
convert the polygon to a polyline, that should take care of the -1 since a point in a polygon, can't measure the distance to the border, but it can to a line.  As for the Euclidean distance, try near with the polyline and points layer
Sort of like this?
VigneshP1
Thanks for the instructions Dan and sorry for the late reply.
I will try it asap, need to get access to a system with arcgis installed.
