.setDefinitionExpression using geometry?
4522
15
05-29-2018 06:43 AM
JamesCrandall
Probably multiple ways to handle this, but I need to set a definition expression on a polygon FeatureLayer using the intersection of another polygon FeatureLayer.  I had been simply using a WHERE clause on an attribute, but the requirement has changed to use the geometry from a different FeatureLayer.
Any help is appreciated.
What I have so far:
createFuncLocLayer: function () {
      this.funcLocLayer = new FeatureLayer(this.config.functionalLocationLayer);
      this.workplanBoundaryLayer.queryFeatures(this.queryWorkplanLayer(), lang.hitch(this, function (result) {
        var wpGeometry = geometryEngine.geodesicBuffer(result.features[0].geometry, -20, "meters")
        //How can I apply this.funcLocLayer.setDefinitionExpression to use the wpGeometry variable?
RobertScheitlin__GISP
James,
   A Query class has a where property and a geometry property. You may be use to using the where but you can also just use the geometry property instead or or in addition to the where property.
  var def = new Deferred();
  if(!this.workplanBoundaryLayer.loaded){
    this.workplanBoundaryLayer.on("load" lang.hitch(this, function(){
      def.resolve(this.workplanBoundaryLayer.graphics[0]);
  }else{
  def.then(lang.hitch(this, function(result){
    var geom = result;
    var wpGeometry = geometryEngine.geodesicBuffer(geom, -20, "meters");
    var query = new Query();
    query.outFields = ["*"];
    query.returnGeometry = true;
    query.outSpatialReference = this.map.spatialReference;
    query.geometry = wpGeometry;
    this.funcLocLayer.queryIds(query, lang.hitch(this,function(objectIds) {
      var qStr = this.funcLocLayer.objectIdField + " IN(" +objectIds.join(',') + ")";
      this.funcLocLayer.setDefinitionExpression(qStr );
James,
   You can not use a Geometry in a layers definition expression. What you have to do is turn that geometry into a sql expression. So you use the geometry to query the OIDs of the layer that intersect (or what ever spatial relationship you want) and then send that array of ObjectIds to the layer definition expression.
    var wpGeometry = geometryEngine.geodesicBuffer(result.features[0].geometry, -20, "meters");
    //Add other necessary query prperties such as spatial relationship
JamesCrandall
hmm.  So I will need to first select on funcLocLayer, collect OID's and then use those to setDefinitionExpression on that same FeatureLayer?
James,
   Maybe you better explain your workflow.
JamesCrandall
I have two polygon Feature Layers:
  • FeatureLayer1 always has a single(1) polygon feature.
  • FeatureLayer2 has thousands of polygon features.
Requirement: Apply definition query/expression to FeatureLayer2 so that the only features available (throughout the entire session) in the map are those that intersect with the single polygon in FeatureLayer1.
James since FeatureLayer1 will only ever have on Polygon you don't really need a query for that. Just make sure FeatureLayer1 is loaded and grab the first graphic.
i.e.
var geom = FeatureLayer1.graphics[0];
Then run a query on FeatureLayer2 using the geom from the previous as mentioned earlier and then apply the definition query to FeatureLayer2.
JamesCrandall
Good point.
JamesCrandall
It's very unclear to me how to .execute on the queryTask without having to jump to another showResult function.  Also, I haven't found how to replace the query.where with a query.geometry property.
Do you have any examples of querying with the geometry?
James,
  }else{
    var geom = result;
JamesCrandall
Thank you for that!
I never would have thought to implement what you did there with the Deferred.  So many unknowns.  Overwhelming really.
Is there an ending ")" missing for this?
I get an "expected ;" error here on the second ")":
})); //error on this line says "expected ;"
}else{
