.setDefinitionExpression using geometry?
4913
15
05-29-2018 06:43 AM
JamesCrandall
Probably multiple ways to handle this, but I need to set a definition expression on a polygon FeatureLayer using the intersection of another polygon FeatureLayer.  I had been simply using a WHERE clause on an attribute, but the requirement has changed to use the geometry from a different FeatureLayer.
Any help is appreciated.
What I have so far:
createFuncLocLayer: function () {
      this.funcLocLayer = new FeatureLayer(this.config.functionalLocationLayer);
      this.workplanBoundaryLayer.queryFeatures(this.queryWorkplanLayer(), lang.hitch(this, function (result) {
        var wpGeometry = geometryEngine.geodesicBuffer(result.features[0].geometry, -20, "meters")
        //How can I apply this.funcLocLayer.setDefinitionExpression to use the wpGeometry variable?
RobertScheitlin__GISP
James,
   I forgot the comma after the "load".
this.workplanBoundaryLayer.on("load", lang.hitch(this, function(){
JamesCrandall
I don't know how I missed that.
Thank you
JamesCrandall
Robert -- I'm marking as correct cause I don't doubt this is what I need to implement.  Still working thru a problem of "result" = undefined and causing an issue setting the wpGeometry var.  I'll see if what I'm doing wrong there.
def.then(lang.hitch(this, function(result){
                debugger
                if (result) {
                    var geom = result;
                    var wpGeometry = geometryEngine.geodesicBuffer(geom, -20, "meters");
                    var query = new Query();
                    query.outFields = ["*"];
                    query.returnGeometry = true;
                    query.outSpatialReference = this.map.spatialReference;
                    query.geometry = wpGeometry;
                    debugger
                    this.funcLocLayer.queryIds(query, lang.hitch(this, function (objectIds) {
                        var qStr = this.funcLocLayer.objectIdField + " IN(" + objectIds.join(',') + ")";
                        this.funcLocLayer.setDefinitionExpression(qStr);
JamesCrandall
Robert,
Thanks again!
I was struggling with making your solution/suggestion error-free and found the issue (pretty typical struggle for me, not sure how else to pick these out faster, I think I'm getting a bit better tho).  It finally makes it to qStr and I believe sets the definitionExpression as desired:
var geom = result;
Should be
var geom = result.geometry;
James,
   Sorry about that. The returned value from the deferred was a graphic and you where needing a geometry.
RichardReinicke
Hi James,
I haven't tried this out but I think you have to use FeatureLayerView or execute a query on the FeatureLayer and create a layer for visualization from the results?
FeatureLayerView | API Reference | ArcGIS API for JavaScript 4.7
var query = new Query({
   geometry: wpGeometry,
   spatialRelationship = "intersects"
// YOU CAN USE LAYERVIEW WHICH YOU CAN USE TO HOOK INTO LAYERS UPDATE EVENT
view.whenLayerView(this.funcLocLayer).then(function(lyrView){
  lyrView.watch("updating", function(val){
    if(!val){  // wait for the layer view to finish updating
      lyrView.queryFeatures(query).then(function(results){
        // Do additional stuff
// OR USE THE QUERY DIRECLY ON THE LAYER
this.funcLocLayer.queryFeatures(query).then(function(results){
  // Create the final layer and add to map or update an existing layer
Let me know if this helps.
