Multifactor Authentication
2205
04-20-2018 11:30 AM
PaulGiard
Is there a plan to add multifactor authentication to Enterprise Portal?
If not how can this be achieved?
JacobBoyle412
You can use a 3rd party SAML that supports 2 factor authentication. Several SAML/ADFS solutions exist.
Jacob is a Sr. Solution Architect for Esri Professional Services and loves conservation planning, woodworking, LEGO, and his dogs.
NickHarvey
@JacobBoyle412  - Hi Jacob - Please see the highlighted text  in the attached pic (and at bottom).  Do I take this to mean that 3rd party SAML with multifactor authentication will work with AGOL?  But that the AGOL-based multifactor option won't work with a SAML login?   The text in the attached pic reads: "Multifactor authentication is not supported for SAML logins,...".  Sorry, I'm reading it both ways...Any help appreciated...
-Nick
JacobBoyle412
@NickHarvey: that explains the disconnect, I was speaking to ArcGIS Enterprise.
You should post this question in the ArcGIS Online channel, I was answering from an ArcGIS Enterprise perspective.
NickHarvey
Hey Thanks Jacob, you were correct  - Got it answered in a reply to the post below and at very bottom link (below).  MFA can be done with AGOL using your own SAML basically.
https://community.esri.com/t5/esri-software-security-privacy-blog/protect-your-assets-use-multi-fact...
https://trust.arcgis.com/en/documents/Organization-Specific%20Logins%20FAQ.pdf
