Setting default values in web maps
2450
04-12-2018 02:47 PM
JAVIERVARA_SANZ
In my workflow, I want to use the same hosted feature layer, but be able to apply different default values for two different web maps. I've noticed the default values are applied at the hosted feature layer rather than at the web map level, which keeps creating issues in this regard when editing data through collector.
Ideally I would like to be able to set the default values similar to the symbology or the filters
Any advise or update in any implementation in this regard will be highly appreciated.
KellyGerrow
Esri Alum
Thanks for the feedback Javier,
I'd suggest logging this on the ArcGIS Ideas‌ site. Ideas like this can be promoted and commented on to help the development team understand the requirement and the need for other users. Feel free to post the idea back to this discussion once you have it logged.
-Kelly
ChaimSchwartz4
You can create a new layer view, then create a different editing template for that new view. Within the editing template, you can then define a different default value.
