examples of using arcade replace function in AGO popups
3393
03-30-2018 07:50 AM
deleted-user-eL7_ccoObXzi
I have a mapping service that contains a text field with spaces in it. The text is a url. AGO turns the first part of the string into hypertext but leaves the string after the space as text. The URL fails to make the correct request because it is not complete. I want to try replacing the space with another character like % to see if that will execute. I am not finding a lot of good arcade pop up samples or documentation. Any help is greatly appreciated!
Thanks! -tom
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Tom,
Try the following:
Replace($feature.<field name>, ' ', '%')
Ex:
