ArcMap how to add a marker symbol in center of polygon
8099
6
05-17-2017 10:19 AM
JoseSanchez
Hello everyone,
In ArcMap on the symbology tab, is there a way to add a marker symbol in the center of a polygon layer.
The goal is to identify visually a group of  features marking them with a point in the middle of the polygon or other additional marker.
DanPatterson_Retired
You can create a centroid point within the polygons using feature to point If you have fairly regular polygons, then the default location should work, otherwise a 'label point' location will be chosen ensuring placement within the polygon.  You can then choose an appropriate marker for the point and/or label it.  There are other options, but I find that actually having the central locations as their own featureclass helpful in some types of analysis.  If this is purely for cartographic purposes, there are other ways as well.
JayantaPoddar
Right link, wrong Text. It would be Feature to Point
Think Location
Thanks Jayanta... point... polygon .... so close
MattiasEkström
It would be really nice to be able to put together a polygon symbol that shows the area and also display a marker symbol within the polygon. And when you zoom out to an extent where the polygon is really small you'd see the symbol above it. And of course I would like to do this without creating a separate data source. Is there anyway to do this? for example i would like to tell the marker fill symbol to not repeat, just place one single marker. Is this possible?
Another approach could be to label the polygon with a single character matching the desired symbol, but I would like a symbol that contains a combination of several characters. Any Ideas?
deleted-user-OlpHy1NoMNug
Agreed, this would be helpful.  You can do it ArcGIS Pro but I haven't found a way in ArcMap.
MattiasEkström
Glad to hear it's possible in ArcGIS Pro, one more reason to switch to pro, I have to do that soon 🙂
