Unique Indexes in Versioned Feature Classes are not possible?
2547
03-23-2018 08:54 AM
AdrianGay
Dear ESRI Community, This question comes in two parts
Firstly – Can anyone confirm that if the Feature Classes we create are versioned this means then that it is IMPOSSIBLE to create unique indexes on any of the Feature Class Columns? You cannot therefore constrain unique data in any of the Feature Classes.
Secondly – This being the case has anyone a possible work round for this problem? Not being able to constrain uniqueness in data model fields is a fairly basic requirement.
You may be asking....  why ask this question…
Why do we want versioned Feature Classes – for offline capability
Why do we want uniqueness on fields – to force data integrity
It would seem in this thread this lack of capability (no unique indexes) is documented - https://community.esri.com/message/614898
Has anyone else found this a limitation?
Any suggestion on how to get round this?
Grateful for any suggestions
Regards Adrian
ChrisDonohue__GISP
I'm not sure if this will directly answer your question or be the exact solution, but one topic you may want to explore is the use of Global ID's for data replication.
GlobalID
  1. [ESRI software] A field of type UUID (Universal Unique Identifier) in which values are automatically assigned by the geodatabase when a row is created. The GlobalID field is necessary for maintaining object uniqueness across replicas. All feature classes and tables participating in one-way or two-way replication must contain the GlobalID field. This field is not editable and is automatically populated when it is added for existing data.
Source:  globalid | Definition - Esri Support GIS Dictionary
Add Global IDs—Help | ArcGIS for Desktop
Chris Donohue, GISP
AdrianGay
Hi thanks for the comment
Most of our data objects have a Global ID so that the entire records are unique ... this is not really the question I was asking - I am looking to constrain  data fields for uniqueness (normally done with unique index on a field / column )  - which appears to be not possible when the data objects are versioned.
