Script Tool - Works on desktop but not on citrix
1714
03-23-2018 06:32 AM
ChrisHolmes
I have a small script tool that works fine in desktop version of arcmap but when I try to run it from the catalog tab in the citrix version of arcmap I get the following error:
I found the following link related to the error 000824:
https://support.esri.com/en/technical-article/000013100
Adding the arcpy.CheckOutExtension makes no difference to the error.
Here is the code for the script:
import arcpy
locno = arcpy.GetParameterAsText(0)
year = locno[3:7]
inFc = "//work/work/plan/luam/1p2007/" + year + "/" + locno + "/data_for_item.gdb|data/proposed_LOC_polygon"
outFc = "//work/work/plan/luam/1p2007/" + year + "/" + locno + "/data_for_item.gdb|data/site_location"
arcpy.AddMessage('in: ' + inFc)
arcpy.AddMessage('out: ' + outFc)
arcpy.CheckOutExtension('AgendaMapping')
arcpy.FeatureToPoint_management(inFc,outFc)‍‍‍‍‍‍‍‍‍‍
I wonder if it could have anything to do with the licensing level that I may have for arcmap citrix? I'm just taking a guess on this based on the "The tool is not licensed" comment.
Any thoughts appreciated.
ChrisHolmes
Figured it out. It has to do with the license level running on our server vs my desktop. I have advanced license on my desktop, they have standard license running on our server. arcpy.FeatureToPoint_management requires advanced license. That's why it worked on my desktop but not on the server.
Would be nice to find a list of what license level is required for all functions.
PanagiotisPapadopoulos
Maybe you have to set the ArcGIS Desktop License by this
How To: License ArcGIS Desktop on Citrix
ChrisHolmes
Thanks, I’ll check it out.
ChrisHolmes
