Get the token using ArcGIS Python API
26661
16
03-13-2018 10:59 PM
simoxu
by MVP Alum
Hello folks,
Can anyone give me a clue how to access token using ArcGIS Python API?
I believe a token was generated when instantiating the GIS class as follows:
from arcgis.gis import GIS
gis=GIS(url="https://...",username="",password="")
I thought the token should be stored somewhere in the gis object, I looked up and down the list of properties and methods but nowhere can I find it.
Any advices and suggestions are highly appreciated.
Simo
JakeSkinner
Esri Esteemed Contributor
Hi Simo,
Yes you can find this with the following:
import arcgis
gis = GIS("https://www.arcgis.com", "jskinner_CountySandbox", "*****")
token = gis._con.token
print(token)
JakeSkinner
Hi Simo,
import arcgis
print(token)
simoxu
by MVP Alum
Hi Jake,
That works! Thanks a lot.
Simo
RohitSingh2
Hi Simo,
Would you mind sharing why you need access to the token though? Is there something in the API or your workflow that needs access to this token?
Rohit
simoxu
by MVP Alum
Hi Rohit,
I am migrating some code built roughly 3 years ago using ArcREST. In one piece of the code, I need to download the data in the feature service(create Replica) and save the data in a local database.
As you know, the replica will be stored in AGO organization as the following:
http://services1.arcgis.com/pdfadfdafkkllADFAA/ArcGIS/rest/services/RIASP22015/FeatureServer/replica...
To download the zip file and unzip it, I need a token to access AGO organization. This was required in my old code, and I am doing a like for like migration at the moment.
Hope this explains it.
Cheers,
Simo
JakeSkinner
Hi Simo,
Just an FYI, you can use the following tool to download your data:
https://community.esri.com/docs/DOC-6496-download-arcgis-online-feature-service-or-arcgis-server-fea...
simoxu
by MVP Alum
Thank you Jake.
AllisonMuise2
@RohitSingh2 are there any plans to add the ability to access & download replicas directly through the Python API? I am running into this same issue as @simoxu . The Python API can get us so close, but then to need to use requests to get the path to the output is a bit disappointing. The API has spoiled us by making most of these actions so easy!
DCWORK_GIS
I know this is an old post, but I'm wondering if there is a newer convention for accessing the authentication token? I've been using:
gis = GIS("home")
print("Token: " + str(gis._con.token))
which worked up until our org updated to 3.2 from 2.9, but doesn't work anymore - gis._con.token now returns 'None', whereas previously would return the token string.
sredar
Try this, you will have to import the arcpy module,
token = (arcpy.GetSigninToken())['token']
