Get the token using ArcGIS Python API
26576
16
03-13-2018 10:59 PM
simoxu
by MVP Alum
Hello folks,
Can anyone give me a clue how to access token using ArcGIS Python API?
I believe a token was generated when instantiating the GIS class as follows:
from arcgis.gis import GIS
gis=GIS(url="https://...",username="",password="")
I thought the token should be stored somewhere in the gis object, I looked up and down the list of properties and methods but nowhere can I find it.
Any advices and suggestions are highly appreciated.
Simo
DCWORK_GIS
That does work, but in my case, my goal is to use this script, and others like it in AGOL Notebooks, and my org doesn't pay for ArcPy there. So I'm limited to only using the API for Python.
sredar
What the heck, now I am getting the same thing you are with
token = gis._con.token
Its returns None and just yesterday it worked
In a Notebook it does works but it no longer  my in local IDE.
DCWORK_GIS
But yesterday it did? That's really weird. I noticed it after we upgraded from 2.7 to 3.2, but maybe it's something else. ESRI's been non-responsive about the issue. Maybe it's a bug.
sredar
The issue appears to be related to how you access the 'gis', this works:
gis = arcgis.GIS(url='https://{org}.maps.arcgis.com/', username=user, password=pswrd)
this does not:
gis = arcgis.GIS("pro")
vpelleritoCritigen
This is bad... Now, even though the user is logged into the Portal in Pro, you must pass those same credentials hardcoded in your Python script.
Thanks, @sredar for discovering this.
JRhodes
Same issue here. @sredar's workaround is great for my current project (thanks), but there are lots of other cases where arcpy isn't available and I need to get an access token from the GIS object.
Matthew_Muehlhauser
This is another option for getting the token without needing to store the credentials in the script, but it does require some initial setup on the computer that you plan to run the process on because you need to create a profile that will be used for all your future scripts.1st Run:
gis = GIS("https://www.arcgis.com/", "USERNAME", "PASSWORD", profile="profile_name")
Future Runs:
gis = GIS(profile="profile_name")
With this, you should be able to access the token using gis._con.token
Note: The credentials should be stored at
Control Panel\User Accounts\Manage your Credentials\Windows Credentials
Update: The GIS module now supports getting the token
gis.session.auth.token
