__geo_interface__ Generates Different and Incorrect Output When ArcPy Not Installed
2919
03-07-2018 09:02 AM
JoshuaBixby
MVP Esteemed Contributor
Hey ArcGIS API for Python staff on GeoNet, I found a bug for you.
It turns out the __geo_interface__ methods generate different, and incorrect, output when ArcPy is not installed along with ArcGIS API for Python.
>>> from arcgis.geometry import Geometry
>>> from pprint import pprint
>>> # simple square with a hole in the middle
... json = {
...     "rings": [
...             [0, 0],
...             [0, 10],
...             [10, 10],
...             [10, 0],
...             [0, 0]
...             [3, 3],
...             [7, 3],
...             [7, 7],
...             [3, 7],
...             [3, 3]
...     "spatialReference": {
...         "wkid": 3857
>>> # __geo_interface__ output when ArcPy is installed
>>> pprint(Geometry(json).__geo_interface__)
{'coordinates': [[[(0.0, 0.0),
                   (0.0, 10.0),
                   (10.0, 10.0),
                   (10.0, 0.0),
                   (0.0, 0.0)],
                  [(3.0, 3.0),
                   (7.0, 3.0),
                   (7.0, 7.0),
                   (3.0, 7.0),
                   (3.0, 3.0)]]],
 'type': 'MultiPolygon'}
>>> # __geo_interface__ output when ArcPy is not installed
{'coordinates': [[[(0, 0),
                   (0, 10),
                   (10, 10),
                   (10, 0),
                   (0, 0)]],
                 [[(3, 3),
                 (7, 3),
                 (7, 7),
                 (3, 7),
                 (3, 3)]]],
Notice when ArcPy is not installed, the __geo_interface__ output contains an extra closing bracket on the outer ring of the polygon, thus turning a single-part polygon with a hole into a overlapping multi-part polygon.
RohitSingh2
Thanks for letting us know. We've created a bug report and will look into fixing these issues.
DanPatterson_Retired
And float vs integer as well.
JoshuaBixby
Some additional information for the ArcGIS API for Python team.  This issue affects any geometry properties or methods that rely on Shapely when ArcPy is not installed:
>>> json = {
...     "rings": [
...             [0, 0],
...             [0, 10],
...             [10, 10],
...             [10, 0],
...             [0, 0]
...             [3, 3],
...             [7, 3],
...             [7, 7],
...             [3, 7],
...             [3, 3]
...         "wkid": 3857
>>> geom = Geometry(json)
>>> geom
{'spatialReference': {'wkid': 3857}, 'rings': [[[0, 0], [0, 10], [10, 10], [10, 0], [0, 0]], [[3, 3], [7, 3], [7, 7], [3, 7], [3, 3]]]}
>>> type(geom)
<class 'arcgis.geometry._types.Polygon'>
>>> # geometry properties that don't rely on Shapely when ArcPy is not installed
>>> geom.point_count
10
>>> geom.part_count
>>> geom.is_multipart
False
>>> # geometry properties that do rely on Shapely when ArcPy is not installed
>>> geom.area
ParseException: Expected number but encountered ','
  File "<stdin>", line 1, in <module>
  File "C:\...\Continuum\miniconda3\envs\arcgis\lib\site-packages\arcgis\geometry\_types.py", line 585, in area
    return self.as_shapely.area
  File "C:\...\Continuum\miniconda3\envs\arcgis\lib\site-packages\arcgis\geometry\_types.py", line 517, in as_shapely
    return wkt.loads(self._wkt())
  File "C:\...\Continuum\miniconda3\envs\arcgis\lib\site-packages\shapely\wkt.py", line 10, in loads
    return geos.WKTReader(geos.lgeos).read(data)
  File "C:\...\Continuum\miniconda3\envs\arcgis\lib\site-packages\shapely\geos.py", line 254, in read
    "Could not create geometry because of errors "
shapely.errors.WKTReadingError: Could not create geometry because of errors while reading input.
The bad code appears to be in __geo_interface__ property of arcgis.geometry._types .
RohitSingh2
JoshuaBixby
I have confirmed this is fixed in version 1.5
