Project UTM point to DD
4364
11
02-27-2018 08:15 AM
BrianBulla
Honored Contributor
I'm trying to emulate the screen cap below into some JS.
In the SDK for Project there is no parameter specified for the Input Spatial Reference like there in the above screen cap of the Geometry Service I am using, so I'm not quite sure how I specify that in my JS.  Here is what I have so far:
view.on("click", function (event) {
              event.stopPropagation(); // overwrite default click-for-popup behavior
              // Get the coordinates of the click on the view
              var northing = event.mapPoint.y;
              var easting = event.mapPoint.x;
              var geomSer = new GeometryService("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/Geometry/GeometryServer");
              var params = new ProjectParameters();
              params.geometries = [event];
              params.outSpatialReference = 4326;
              var newPoint = geomSer.project(params);
              view.popup.open({
                  // Set the popup's title to the coordinates of the location
                  title: "Latitiude: " + newPoint.y + ", Longitude: " + newPoint.x,
                  content:  "Northing: " + northing + ", Easting: " + easting,
                  location: event.mapPoint // Set the location of the popup to the clicked location
Any guidance is appreciated.
KenBuja
MVP Esteemed Contributor
You have to wait until the GeometryService's project method returns a Promise to get the newPoint properties
geomSer.project(params).then(function(newPoint) {
  view.popup.open({
}, function(error){
 console.error(error);
RobertScheitlin__GISP
Brain,
   The input geometries are expected to already have their spatial reference defined in the geometry.
KenBuja
  view.popup.open({
}, function(error){
BrianBulla
Honored Contributor
Hi Ken, Robert,
Yes, I've looked more into the Promise and how the .then is working, so it makes more sense now.  Still not quite working.  No error messages, just no response on the click event.  Can you see where things might be going wrong??
Here is my entire code.  Basically I'm just using the samples and messing with them.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Manhole WebMap - 4.6</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #info {
      background-color: black;
      opacity: 0.75;
      color: orange;
      font-size: 18pt;
      padding: 8px;
      visibility: visible;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.6/esri/css/main.css">
  <script src="https://js.arcgis.com/4.6/"></script>
  <script>
      require([
        "esri/views/MapView",
        "esri/WebMap",
        "dojo/domReady!",
        "esri/tasks/GeometryService",
        "esri/tasks/support/ProjectParameters"
      ], function (
        MapView, WebMap, GeometryService, ProjectParameters
           * Creates a new WebMap instance. A WebMap must reference
           * a PortalItem ID that represents a WebMap saved to
           * arcgis.com or an on-premise portal.
           * To load a WebMap from an on-premise portal, set the portal
           * url with esriConfig.portalUrl.
          var webmap = new WebMap({
              portalItem: { // autocasts as new PortalItem()
           * Set the WebMap instance to the map property in a MapView.
          var view = new MapView({
              map: webmap,
              container: "viewDiv"
          view.ui.add("info", "bottom-right");
              geomSer.project(params).then(function(projectedPoint){
                  view.popup.open({
                       //Set the popup's title to the coordinates of the location
                      title: "Latitude: " + projectedPoint.y + ", Longitude: " + projectedPoint.x,
              }, function(error) {
  </script>
</head>
<body>
    <div id="viewDiv"></div>
    <div id="info">
        <span id="name"></span>
    </div>
</body>
</html>
I'm doing all this in an HTML file.  I'm relatively new to web programming.  What is the best way to debug this?  Can I do it in Visual Studio like I would with an ArcPro C# project??
KenBuja
Your function arguments have to be in the same order as the require modules. See this blog for more details: The abc’s of AMD | ArcGIS Blog
require([
  "esri/WebMap",
  "esri/tasks/support/ProjectParameters",
  "dojo/domReady!"
], function (
I use the debugging tools in Visual Studios when create a project like that. You should also get in the habit of using the browsers' debugging tools.
Brian,
   The one thing I see now in your code is this line:
it should be:
params.geometries = [event.mapPoint];
Debugging is best done in your browsers developer tools in my opinion (I am partial to Chrome).
BrianBulla
Honored Contributor
Thanks Robert.  Yes, that was a problem, but not the ultimate issue.
It seems like in debug mode the code stops at this line:
var geomSer = new GeometryService("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/Geometry/GeometryServer/project");
Do I have that URL right?  With (or without) the /project does not seem to matter.  I get a GeometryService is not a constructor error.
Even after applying Ken latest reply about the require order?..
BrianBulla
Honored Contributor
Sorry, I didn't see Ken's second post there.
But....I have made his changes to the order, so now I get past the URL issue, but now another error is coming up relating to the outSpatialReference:
Brain,
   It does not look like projectParams autocasts the outSpatialReference from a number like you are providing. So you have to add the Require for SpatialReference and give it a true SpatialReference class and not just 4326.
