How do I pass multiple ObjectIds as Number[] delimited list to execute a relationship query
2735
02-27-2018 01:09 PM
AnikaHirt
I'm trying to make a relationship query with the returned object ids from a previous query but having trouble passing multiple IDs
var query = new Query();
query.returnGeometry = false;
query.outFields = ["OBJECTID"];
query.where = requestTerm;
myQueryTask.execute(query, function(results) {
    if (results.features.length > 0) {
        var ids = [];
        for (var i = 0; i < results.features.length; i++){
            ids(Number(results.features[i].attributes.OBJECTID));
        query = new RelationshipQuery();
        query.objectIds = [ids];
        query.relationshipId = 1;
        myQueryTask.executeRelationshipQuery(query, function(set) {
I also tried to set the IDs with
ids(new Number(results.features[i].attributes.OBJECTID));
 as well as directly, but nothing seems to work.
query.objectIds = [304,305,306];// and casted
query.objectIds = [Number(304),Number(305)];
but nothing seems to right.
Any suggestions or is there an example with multiple ObjectIds?
RobertScheitlin__GISP
Anika,
  You should do:
ids.push(results.features[i].attributes.OBJECTID);
Better yet do a executeforids on your first querytask.
https://developers.arcgis.com/javascript/3/jsapi/querytask-amd.html#executeforids
The result will be a array of object id numbers.
Anika,
  You should do:
AnikaHirt
Thanks. I just realised my mistake was somewhere else but the executeforids option is much nicer so I changed it to that.
Great,
   Don't forget to mark this question as answered.
