ArcGIS Clipping
1510
02-26-2018 04:38 PM
Mitchell_Crameri
I am new to ArcGIS and have come across a problem. I am using Climond Data (.asc file) but need to reduce the area to only include Australia. When I clipped the layer using the Toolbox --> Raster --> Clip, the new file that was created changed to a .ovr/.adf file/s. I am wondering how to either change the newly created files back to an .asc file (only keeping Australia) or how to clip the file and not have it change in the first place.
I am sure this is easy once you know how to do it but I just can't seem to figure it out.
Thank you.
DanPatterson_Retired
Raster to Ascii ... to convert back to ascii.  The tool exists in both ArcMap and Pro
For rasters, the recommended raster format is the *.tif.  Just make sure you specify the file extension to get the proper output
Mitchell_Crameri
Hi Dan,
Thank you for the reply. I have seen that page but have never used python before and was hoping there was an in ArcGIS method to complete this task. But I will download python and give it a go. I have been using .tif but in this case I need the ascii file for another program.
It is actually a tool in ArcToolbox... no programming required... they are just explaining the principles
