Error in a Project tool: Table already exists
4056
02-18-2018 07:38 PM
MarkMindlin
We use a Project tool with a feature dataset (input) and have an error: "Table already exists".
We try to project a feature dataset and put the output to the same geodatabase.
On the same feature dataset, we run a tool Copy without any problem (It creates a copy of the feature dataset (we put a parametre OldName_Copy) and feature classes automatically have names OldName_1, OldName_2 ....)
It would be logical to have the same behavior with a Project tool.
It works ok with file geodatabase output (feature classes automatically have names OldName_1, OldName_2 ....)
How to make it working with a database?
Informix database. Desktop 10.5.0
JayantaPoddar
I am able to run Project tool successfully using ArcMap 10.5. All the FCs get suffixed with "_1" in another Feature Dataset within the same File GDB.
Not sure if it is any different for Informix.
Think Location
shan_sarkar
Can you check the same with a different machine or a different user profile?
~Shan
~Shan
