arcgis 10.5 bridge pyt file is seems broken
430
6
02-15-2018 11:34 PM
saffeterdogan
ShaunWalbridge
Thanks. Could you download the latest version of the installer (or git pull to update), and try again? I added a fix for this issue.
Cheers,
Shaun
ShaunWalbridge
Hello Saffet,
Could you elaborate on what isn't working? Is the installer not working, or you're unable to run the bridge once it's installed?
Shaun
saffeterdogan
ShaunWalbridge
OK, thanks. Can you right click on the toolbox and select "Check Syntax", then copy the message that provides?
saffeterdogan
File "<string>", line 8, in <module>
File "D:\SCRPT\r-bridge-install-master\rtools\__init__.py", line 17, in <module>
from .install_package import install_package
File "D:\SCRPT\r-bridge-install-master\rtools\install_package.py", line 45, in <module>
PACKAGE_VERSION = r_pkg_version()
File "D:\SCRPT\r-bridge-install-master\rtools\rpath.py", line 491, in r_pkg_version
r_package_path = r_pkg_path()
File "D:\SCRPT\r-bridge-install-master\rtools\rpath.py", line 466, in r_pkg_path
handle_fnf(error)
File "D:\SCRPT\r-bridge-install-master\rtools\rpath.py", line 57, in handle_fnf
log_exception(exception)
File "D:\SCRPT\r-bridge-install-master\rtools\rpath.py", line 72, in log_exception
log.debug("Exception generated: {}".format(str(err).decode(enc, 'ignore')))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xfd in position 34: ordinal not in range(128)
ShaunWalbridge
Cheers,
Shaun
saffeterdogan
Thanks a lot
