How can I join two 'arc.data' sets and then export by 'arc.write' giving a vectorised gdb?
785
02-07-2018 03:10 AM
NoraQuesada
I have two datasets with the same format and common fields; read in R through arcgisbinding package and to data.frame format by 'arc.select()'. I ran the join (type='full') function (plyr package) between the two but the resulting class is not 'arc.data' any more and seems to have lost its spatial data representation; when opening ArcGIS I can only see the joined table as an attribute table. How can I preserve the spatial information so I can then see the vecotrised data in my GDB file?
ShaunWalbridge
Hello Nora Quesada‌,
The current stable version of the bridge doesn't directly support dplyr, but you can try the pre-release for the next version, which does support dplyr. Could you try that version? It's available here:
  Release v1.0.1.229 · R-ArcGIS/r-bridge · GitHub
To install it, you can either place the downloaded .zip file into the same directory as the r-bridge-install toolbox, or you can install it directly from R following this screencast.
Shaun
