How To Install the JavaScript API v4.6 for use with ArcGIS for Server
3410
6
02-12-2018 08:30 PM
JunaidSarfraz
I am deploying arcgis javascript library and sdk v4.6 in an IIS server locally (no internet connection) using this tutorial . While following the tutorial I have figured out that it might be only for v3.x because
While configuring
Javascript API CSS2 URL
to
http://myhost.example.com/arcgis_js_api/library/3.16/3.16/esri/css/esri.css
I realize that there is no esri.css file found in
v4.x, rather I found main.css and view.css. So for now I use main.css as Javascript API CSS2 URL.
Config
Now I publish a testService in arcgis server. When I try to view the service unfortunately I see blank page. Below is my network log having javascript loading errors
Network log
It seems that the two javascript (ArcGISDynamicMapServiceLayer.js and ArcGISTiledMapServiceLayer.js) files are missing. I checked that these files are only present in v3.x not in v4.x. Now if I copy these file from v3.x to v4.x I got many other errors w.r.t. other javascript files loading issue.
Question:
1) Can we deploy v4.x locally (no internet) on server ?
2) If yes then am I following right tutorial or am I missing any step while configuring ?
P.S. I downloaded v4.6 from here
RobertScheitlin__GISP
Junaid,
   Are you attempting to configure your on premise Portal installation to use the 4.x JS API?
JunaidSarfraz
Thanks for reply Robert. I am not using "Portal for ArcGIS". I have bought argis server with license. So I installed arcgis server on my private offline server and now using javascript v4.x to develop web application.
Junaid,
   I don't think that you can configure a Federated ArcGIS Server to use JS API 4.x.
JunaidSarfraz
Robert,
   Can you provide an (official-esri) link that confirm your statement ?
Junaid,
   I can not. You would need to contact your local esri support for that.
ReneRubalcava
Esri Frequent Contributor
If you downloaded the JSAPI from the download pages here, the download has instructions on installing to a local server. The instructions should be specific to the version of the API, if not please let us know.
You can't replace the version of the API used by ArcGIS Server to view the services, the download would be to just develop applications in your intranet and have them all reference your locally hosted API.
