Having trouble configuring Public Notification Widget in Web AppBuilder
11233
24
02-12-2018 11:17 AM
deleted-user--MMnVrog9xw_
I am attempting to use the Public Configuration widget in Web AppBuilder on ArcGIS online. I created a web map that contains a map service layer with our county parcels, and then created a Web AppBuilder app from that map. I added the Public Notification widget but when I click on it, it says "No layers with addresses templates popups have been configured". When I go into the configuration no layers show up under the "Address Layers" tab.
I have configured the popups for the parcels layer with the following expression:
{relationships/0/FULLNAME}
{relationships/0/MAILINGADDRESS}
{relationships/0/CITY}, {relationships/0/STATE}, {relationships/0/ZIPCODE}
This seems to match the screenshot that is in the documentation for the widget but the documentation is pretty vague on how to configure the layer for use with the Mailing notification widget.
What do I need to do to get the configure the feature layer so that it is usable with the Public Notification Widget?
Tags (1)
RobertScheitlin__GISP
James,
  One or more layers in your web map have to have their popup enabled with a description then you will see that layer as a choice in the Address Layers list.
Robert,
The popups are enabled for the feature layer.
But the popups have to use the description part of the popup.
What do you mean by "the description part of the popup"? I have the popup set to display "A custom attribute display" like it shows in the documentation.
After you chose the "A custom attribute display" dropdown option did you click on the green configure button and add some fields to the description text area?
Yes, that is the expression that I posted in my original post above.
Strange. Have you tried it with attributes from the layer itself and not a relationship? I have it working without using a relate.
Yes, I just tried that and it still shows nothing in the widget. Are you using a Map Server or Feature Server layer?
Edit: I switched to using a Feature service instead of Map Service and it seems to be working now. I guess that was my issue.
Mine is coming from a Map Server. Also for testing purposes can you add some static text in with the related table field names?
