2.1.1 Upgrade Error
2389
7
02-09-2018 09:25 AM
MKa
I upgraded to ArcGIS Pro 2.1.1 and all of a sudden i was getting this error whenever i tried to set an inspectors attribute
"This method or property must be called on the thread this object was created on"
I had never wrapped my inspector in queuedtask before this upgrade, but now am i required to with the upgrade from 2.0.8933 to 2.1.1?  Will this affect my users running the 2.0.8933 version of ArcGIS Pro?
QueuedTask.Run(() =>
       inInspector[fieldName] = newValue;
by Anonymous User
Not applicable
I can reproduce this, thanks. Although we recommended to do operations on the worker thread, this pattern should work as the inspector is free threaded. We'll take a look.
MKa
Could this have anything to do with why my Initial Inspector in my rowcreated event in my module is no longer returning the Created/Modified dates.  Did something get fixed with the Inspector that I create from the Row in the RowCreated event?  I am experiencing a number of issues with 2.1.1 release and I think they all have to do with some inspector changes.
by Anonymous User
Not applicable
It should be independent but im not ruling out anything at the moment. No progress yet.
MKa
Can you confirm that the Created/Modified and CreatedBy/ModifiedBy are no longer available on the Row sent to the Row Created event in Moduule.  It this is the case we might have a big problem and I will have to roll back my Pro version and my SDK. I know this previously worked before my upgrade to 2.1.1.
by Anonymous User
Not applicable
Whats the version of your server/portal where the feature service is?
MKa
We are using Server 10.5.1 with this feature service and that has not changed in quite a while
by Anonymous User
Not applicable
The inspector thread issue is now fixed for 2.2
I'm waiting for some responses on the feature service issue.
