Add Raster using ArcGIS Rest API through jQuery
1807
6
02-08-2018 09:39 AM
Wondimagegn_TesfayeCIAT
Dear Community,
I am trying to publish image server when a user uploads a file on a Web App Builder app. I tried to use esriRequest to make the request but it is only submiting it as GET even with usePost: true. That is one problem but not the major for now.
The code below results in 400 error code.
The image service url is
http://climatewizard.ciat.cgiar.org/arcgis/rest/services/targeting_tools/africa_land_use/ImageServer...
var wkid = this.map.spatialReference;
var srid = wkid.wkid;
var params = {
    'itemIds': itemID,
    'rasterType': 'Raster Dataset',
    'f': 'json',
    "spatialReference": {'wkid':srid}
    // 'computeStatistics': true
var self = this;
$.ajax({
    type: "POST",
    url: self.config.imageServiceUrl + 'add',
    data: params,
    success: requestSucceeded,
    dataType: 'json'
The response is the following.
{"error":{"code":400,"message":"Requested operation is not supported by this service.","details":[]}}
From the message the image service URL is not able to add raster but I don't know how to create a service that allows adding raster. Could you please help on this one.
Versions being used.
ArcGIS for Servers 10.5
ArcGIS Javascript API 3.22
RobertScheitlin__GISP
As the help documentation states:
Add Rasters
LicenseLicense: As of 10.5, you must license your ArcGIS Server as an ArcGIS Image Server in order to use this resource.
The Image Server service has to be enabled to allow for adding Rasters.
http://climatewizard.ciat.cgiar.org/arcgis/sdk/rest/index.html#/Add_Rasters/02ss0000006r000000/
I see! How could I enable the Image Server service? I have also published some image services already here.
targeting_tools/africa_annual_precipitation (ImageServer)
I though it was enabled.
Unfortunately, there is no option for Upload and download and other useful capabilities. Is it missing because of the type of ArcGIS version?
Only three capabilities
Add Rasters
Oh I see the problem now. Thank you very much for the help!
